Need Opinion on my receiver/speaker setup
Bob Richards
I have just purchased a set of Polk Lsi 9's. I have one receiver a relatively new Yamaha RX-797 and a vintage Sansui AU-X901. The Yamaha is rated at 100 watts while the Sansui is 130 watts. Both can handled 8 and 4 ohm speakers. I bought the Sansui in 1983 and have always loved the way it handled my old SDA floor speakers. Any opinion on which set would give me the most optimal performance on these new Lsi 9's? Will be using Audioquest type 4 cables with gold banana connectors. Thanks for the comments.
Polk Monitor 60's
PSW 10 Sub
Bose Acoustimass 5 Series II
Onkyo TX-8511 Two Channel Receiver
Sony DVP NV800H5 CD/DVD Changer
Denon DP-29F Turntable
AudioQuest 4 Cables
Sansui AU-X901 Integrated Amp
Yamaha RX-797 2 Channel Receiver
Polk Lis 9's
Yamaha 697 CD player
AudioQuest 4 Cables
PSW 10 Sub
AudioQuest 4 Cables
Polk Lis 9's
AudioQuest 4 Cables
Post edited by Bob Richards on
If it were me I would use the Sansui to power the LSi9's and use the Yamaha for a paper weight. YMMV.DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
Yama what?
The Sansui....Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard -
I would say Sansui also.
But I also don't know why you wouldn't try both, since you have both... You never know unless you try....
Nick -
I don't know why dkg made the negative comment about the Yamaha. It's actually a very good 2 channel system. I will give both a try and see which one I like better. Thanks for the inputs.Polk Monitor 60's
PSW 10 Sub
AudioQuest 4 Cables
Polk Lis 9's
AudioQuest 4 Cables -
Because that is Doug's opinion and you asked for opinions.
Be careful with the Yamaha. I used a 90 watt reciever to drive a pair of Klipsh 8 ohm bookshelf speakers and it would start clipping at about half volumn. Fried two sets of tweeters before I gave up on it. Unless they have made vast changes in their recievers, I doubt it will like the 4 ohm load regardless of what they rate it for.
Bob Richards wrote: »I don't know why dkg made the negative comment about the Yamaha. It's actually a very good 2 channel system. I will give both a try and see which one I like better. Thanks for the inputs.
Bob, You probably should try both, keep in mind though, the senior members on here know their stuff, ive improved my system by trial and error and a lot of input from these guys.:DPolk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
So Bob, why is the Yammer a good 2-Ch. system?
Now you should know I dont think it would make that good of a paperweight, however, as an anchor for a small boat it may be useful, at least that is my 02. Well actually its a nickel, but only a nickel on a dime of the entire story.
I am thinking the Sansui, but maybe you can change my mind.
RT1 -
I'll try them both. Thanks for everyone's comments. It was very helpful.Polk Monitor 60's
PSW 10 Sub
AudioQuest 4 Cables
Polk Lis 9's
I would try both but I think the Sansui will win.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
