Bi-Amp Connecting
gmoak
gmoak Posts: 1
I have new A7's and am confused by the bi-amp connection option. How does the bi-amp work? I have two amps - one amp in a stack in the basement that controls all music throughout the house and one amp dedicated for the that the A7's are in. They are not separate amps for high and low frequencies. I would like to connect both amps to the speakers. Can I?
Post edited by gmoak on
  • joev11
    joev11 Posts: 22
    edited January 2009
    You can but the amps will need to be together and near the speakers. Simply run one amp to the binding posts of each of your speakers and the other one to the remaining set of binding posts for each speaker. Generally the more powerful amp will be used to drive the bass.
  • Bass_Pedal
    Bass_Pedal Posts: 196
    edited January 2009
    It sounds like it would make more sense to run the A7's off of the separate amp and leave the other one alone. Why do you want to bi-amp? What amps do you have?
    Mains - Vienna Acoustics Mozart Grand
    Subs - Rel T5 x 2
    Amplification - Bryston 3b cubed
    Pre Amp - Marantz Sc11-1
    SACD - Marantz Sa11-1
    Stream - Cambridge Audio CXN v2
    Dac - Marantz Dac-1
    TT - Pro-Ject RPM 9.1 w/ Ortofon 2M Black Cartidge
    Phono Stage - Project Tube box DS
