What Surround Wall Mounts For FXi/4's?
I'm currently in the process of redoing my living room/HT area, and just picked up some awesome Polk FXi/4's.
But, at 10-11lbs, I'm somewhat iffy on just drilling into the wall (even into a stud or with a screw anchor) with such weight.
Also, I know they're bi-directional, but my previous speakers were a lot smaller and angled down towards the listening area. I have a wide listening space so the speakers have to be directly behind, which is one reason I went with the FXi/4's b/c of their disbursement area being so wide. But would I need to angle them down at all?
Anyway, thoughts? :) Thanks!
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    You'll be just fine hanging them on a wall stud. There are tons of people that have done it before, and I've never heard of anyone having problems with it.
    If they're directly behind you, and not above you I wouldn't think you'd have to angle them down at all.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
