BT77 speaker wall mounts
gold01ca
gold01ca Posts: 50
edited January 2009 in The Clubhouse
anybody using these wall mounts?
comments on quality, ease of install, etc. appreciated.
thanks
Post edited by gold01ca on
  • ViperZ
    ViperZ Posts: 2,046
    edited January 2009
    Mentioning with what speakers you want to use these mounts might help...
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • PSOVLSK
    PSOVLSK Posts: 5,220
    edited January 2009
    I have these mounts and I'd say they are high quality. Mounting is easy...two screws into a wall stud. As Viper mentioned, which speakers you plan to use would help, but the mounts are fairly versatile.
  • gold01ca
    gold01ca Posts: 50
    edited January 2009
  • McLoki
    McLoki Posts: 5,231
    edited January 2009
    They are awesome. Work well and very versitile...
    Do not screw into your speaker though. If you think you have to - ask for help before you break out your screwdriver.
    billbillw Posts: 6,847
    edited January 2009
    I use them for my RT25i and a set of large Mirage bookshelf speakers.
    They are very heavy duty and can hold just about any bookshelf speaker. I recommend using more than 2 screws to mount though. I think there are holes for 4 screws. I used all of them. The base clamps the bottom of the speaker pretty well. They recommend **** the speakers to the base, but I didn't do that. I used a few pieces of blu-tac to stick things down and help eliminate vibrations too.
    IMHO, these are about the best mount out there for large bookshelf speakers. The only drawback is they do not angle down very much. I think the max is only 10 or 12 degrees down. If you mount them too high, you won't be able to fully aim them down to your ears.
    For rig details, see my profile. Nothing here anymore...
  • gold01ca
    gold01ca Posts: 50
    edited January 2009
    thanks for the input folks, I will definitely be picking up a set.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    I have a pair of them that I use for my fronts. I love the fact that you don't have to drill into the speakers to use them...plus they're very adjustable. You can get them to just about any angle you could possibly need.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • shawn474
    shawn474 Posts: 3,052
    edited January 2009
    I have two pairs of these mounts and like them a lot. My speakers have some curve to the cabinet so they don't fit perfectly into the mount. But, Doro gave me the recommendation to use fishing line to secure the speaker. So i put a few loops around the mount and the binding posts and haven't had a problem in a year or so. They're very nice mounts.
    Shawn
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
