Wiring My Rtia5's to my emotiva XPA-3 Help
Hi: I will be adding an external amp to my Polk speakers and I would like some advice on how to proceed for best listen results.
Equipment:
Onkyo 806 avr
Polk Rti a5's
Polk csi3
Polk PSW 505
Polk fx300i's*
I am waiting for delivery of a emotiva XPA 3
Currently I have the Polk Rti a5's set up in a bi-wired mode with the Onkyo 806. I will connect the emotiva XPA-3 to the Rti a5 fronts, and csi 3 center.
1) How should my wiring be configured for best results. It there are instructions somewhere on the Polk Forum, that would do as well.
2) Also, I just purchased the Polk fx300i's from another member in the forum to replace my current crappy HTB Sony surrounds. They are in transit as we speak. Is a good match for the rest of my other speakers? I got them at a good price ( I think), I just want to know if I need to pass these on and go with something else.
3) Should I use any special rca's to connect my XPA-3's and should I have any other special connections ready other than a 3.5mm to 3.5mm for the triggers?
Any insight is greatly appreciated. It's you old school Polkheads that got me hooked on this premium habit
Equipment:
Onkyo 806 avr
Polk Rti a5's
Polk csi3
Polk PSW 505
Polk fx300i's*
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut
Post edited by bklynNupe on
Good setup!!
1. If you aleady have it bi-wired now.....bi-wire it to the Emo when you get it.
2. That should be fine. It all depends on the room dimensions, mounting locations, etc. You be the judge!!
3. I would get quality RCA's. It all depends on what you want to pay. I would get at least BJ IC. If you want to get the most out of your system, get Ben's IC
Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Thanks, I'm looking forward to it.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut -
nice setup!
BKLYN let me know how it sounds when you get it. I also live in brooklyn and I'm waiting for the xpa-5.Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
Velodyne DPS-12 (Sub)
EMOTIVA XPA-5
:cool::p;):)
