What Size Wire for Lsi9's
Bob Richards
Bob Richards Posts: 27
I have a pair of Lsi9's that will be connected to a Yamaha RX-797 receiver. It's a simple 2 channel system. What recommendations are there for which speaker cables are best suited. What size cable should I looking at. Both the Lsi9's and the receiver have 5 way binding posts. Any recommendations on which one is better. Would I increase the quality of sound if I bi-amped the speakers? As you see I am new to all of this. I am not into home theater, just music via DVD, MP3, XM radio and turntable. Appreciated any and all feedback.
Polk Monitor 60's
PSW 10 Sub
Bose Acoustimass 5 Series II
Onkyo TX-8511 Two Channel Receiver
Sony DVP NV800H5 CD/DVD Changer
Denon DP-29F Turntable
AudioQuest 4 Cables
Sansui AU-X901 Integrated Amp
Yamaha RX-797 2 Channel Receiver
Polk Lis 9's
Yamaha 697 CD player
AudioQuest 4 Cables
Post edited by Bob Richards on
  • MKZ
    MKZ Posts: 1,068
    edited January 2009
    Try AudioQuest or Signal Cable. I have had great experience as other suggests.
    You might also want to consider the amp if you are getting serious.
  • Bob Richards
    edited January 2009
    When you say "consider the amp" are you meaning bi-amping" Thanks for the tip on where to purchase, I'll give them a look.
    Polk Monitor 60's
    PSW 10 Sub
    AudioQuest 4 Cables
    Polk Lis 9's
    AudioQuest 4 Cables
  • MKZ
    MKZ Posts: 1,068
    edited January 2009
    I meant separate amp instead of receiver.
    You could use the short piece of speaker wires as jumper instead of bi-wire or bi-amp.
  • curved
    curved Posts: 664
    edited January 2009
    Agree with MKZ - you may want to invest in an amp in the future. Your amp will get mighty hot with the LSi9's and will most likely kick into protective mode. Those things dip down below 4 ohms at times.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
  • emoxley
    emoxley Posts: 205
    edited January 2009
    I use 14 AWG wire with my LSi9s, and it works just fine........
    Samsung HL61A750 LED DLP
    Onkyo TX-SR805 receiver
    Oppo BDP-83 blu ray player
    Polk Audio LSi9 front speakers
    Polk Audio LSiC center speaker
    Sony SS-MB100H rear speakers
    SVS PC12-NSD powered subwoofer
    Pioneer PL-514 turntable
    Logitech Harmony 628 Universal Remote
  • speedster2333
    speedster2333 Posts: 37
    edited January 2009
    I have a pair of LSI9's. I would recommend anything from 9-14 gauge. I run Kimber 8pr bi-wire (2x10 gauge) with a Parasound 2205a and I use the pre-outs on my H/K 354. Don't skimp on wire either, it makes a difference. Try looking into some Kimber Kable it is great stuff.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Quality is more important than ga.
    Ben
  • Bob Richards
    edited January 2009
    Thanks for all your inputs. (couldn't resist the pun) I may use my Sansui AU-X901 on the Lsi9's. I have have had it since the early 80's. It's 130 watts, with 4 and 8 ohms capability, a real beast. i will check out the web recommendations for speaker cables and make a decision in the next few days. Again thanks.
    Polk Monitor 60's
    PSW 10 Sub
    AudioQuest 4 Cables
    Polk Lis 9's
    AudioQuest 4 Cables
  • ben62670
    edited January 2009
    Watch for some Audio Quest type 4's in the used market, or look for the AQ type 4 bulk cable. IT can be found cheap if you keep your eyes out.
    Ben
    Ben
  • beardog03
    beardog03 Posts: 5,550
    edited January 2009
    www.audioadvisor.com
    great deals on AQ cable
    No affil
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • BlueFox
    BlueFox Posts: 15,251
    edited January 2009
    ben62670 wrote: »
    Have to agee with this statement. I have been a 12 guage stranded wire from the hardware store fan, but after upgrading to these Mapleshade Clearview golden Double Helix Plus cables last weekend I am just amazed at the increase in clarity, range, and overall improvement in sound. I swear it is like upgrading the speakers.
    http://www.mapleshaderecords.com/audioproducts/doublehelixspeakercable.php
    A week before I added the speaker cables, I upgraded my digital interconnect to their CLEARVIEW DOUBLE HELIX DIGITAL Plus and it also was a quantom leap forward in sound improvement. Combined with the speaker cables, it produces an such an audio upgrade that I am completely sold on the benefit of using quality interconnects.
    http://www.mapleshaderecords.com/audioproducts/doublehelixdigitalinterconnects.php
    Other than my hardware store speaker cable, and some relatively inexpensive interconnects, this is my first experience with 'expensive' cables, and I have to say I am now a believer.
    In fact, after one week of my digital interconnect sounding so great I decided to buy the an upgrade that cost twice as much ($400) to see what it does.
    http://www.mapleshaderecords.com/audioproducts/planardigitalzephyr.php
    I am so happy I found another way to help save our country from a depression.
  • Bob Richards
    edited January 2009
    Bluefox: I did look at those cables at Mapleshade. Seems like it would be worth considering. Wondered about the connectors. Did not see that they were selling them. Where did you get yours from. What type, Banana, etc. Thanks again for the info.
    Polk Monitor 60's
    PSW 10 Sub
    AudioQuest 4 Cables
    Polk Lis 9's
    AudioQuest 4 Cables
  • ben62670
    edited January 2009
    http://www.audioadvisor.com/prodinfo.asp?number=AQT4B
    Cheap enough at $4 a foot, and you don't need to terminate them.
    (thanks Bear)
    Ben
  • BlueFox
    edited January 2009
    They recommend to not terminate speaker cables. However, for a few dollars extra they will provide your choice of terminators. Here come the Arnold jokes. :)
  • Hawkeye
    Hawkeye Posts: 1,313
    edited January 2009
    I'll second Blue Fox on the Mapleshades ICs and speaker wire! They are a little (ok, alot) unusual looking but for the dollar a very fine wire.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • Bass_Pedal
    Bass_Pedal Posts: 196
    edited January 2009
    Just want to add another vote for Signal Cable. I purchased a set of Signal Cable Ultras for my Lsi'9 and was really suprised at the impovement. For the price, I don't think you can do much better. And the customer service is excellent!
    http://www.signalcable.com/
    Mains - Vienna Acoustics Mozart Grand
    Subs - Rel T5 x 2
    Amplification - Bryston 3b cubed
    Pre Amp - Marantz Sc11-1
    SACD - Marantz Sa11-1
    Stream - Cambridge Audio CXN v2
    Dac - Marantz Dac-1
    TT - Pro-Ject RPM 9.1 w/ Ortofon 2M Black Cartidge
    Phono Stage - Project Tube box DS
  • Bob Richards
    edited January 2009
    Thanks all for your inputs. I decided on AudioQuest Type 4's with banana connectors. Much of the decision was around cost. I hope to upgrade in the forthcoming months.
    Polk Monitor 60's
    PSW 10 Sub
    AudioQuest 4 Cables
    Polk Lis 9's
    AudioQuest 4 Cables
  • zingo
    zingo Posts: 11,258
    edited January 2009
    No doubt there are upgrades from that cable, but that is a great cable to start with and it's going to cost you a lot more to upgrade to the next step.
  • curved
    curved Posts: 664
    edited January 2009
    zingo wrote: »
    Agreed!!
    The Sansui should power those fine. Let us know how it all sounds put together. :D
    Pre - Nak CA-5
    BR - LG BD390
  • Bob Richards
    edited January 2009
    Will do. The AudioQuests should be here in a day or two.
    Polk Monitor 60's
    PSW 10 Sub
    AudioQuest 4 Cables
    Polk Lis 9's
    AudioQuest 4 Cables
    F1nut Posts: 51,766
    edited January 2009
    MIT cables or go home.
  • jabrax
    jabrax Posts: 315
    edited January 2009
    Bob, curious to know how your Sansui handles the 9's.....I started with that 797 Yammie, didn't run the 9's well at all (my opinion). I put an amp in between, and it made a world of difference.
    TV...............Hitachi 42hdS52a plasma (sexy one with the swival)
    Pre/Processor - Emotiva MMC
    Seven Ch AMP - Emotiva LPA
    Fronts - Tyler Acoustics 7U's
    Center - Polk LSIC
    Sub - DSWPRO600
    DAC - Music Hall 25.3CD - Marantz cc4001
    Blue Ray - PS3
    Speaker cables - Audioquest cv4 dbs
    Interconnects - MIT AVT1's
    Power Filter....Monster HTS 3500 MKII
  • Bob Richards
    edited January 2009
    I put the system together today. To tell you the truth I can't tell a notice much difference between the Yamaha or the Sansui. I'll tell you what though those Lsi 9's are the best sounding speakers I've ever owned. I do believe that those AudioQuests cables make a big improvement as well. So far, so good.
    Polk Monitor 60's
    PSW 10 Sub
    AudioQuest 4 Cables
    Polk Lis 9's
    AudioQuest 4 Cables
