analog outputs question
krabby5
I just got a great deal on a Sony S550 Blu-ray player and I have questions about the 5.1 (7.1) analog outputs. I have a Pioneer Elite 72txv receiver, which is a couple 3 years old so it doesnt decode the newest high-def formats. Because of this, I will be using the analog outs from the Sony to my Pioneer. How exactly does this work? Do I just set the Sony player to output via the analog outputs,and I'm good to go?
Will I have to manually adjust the bass mgmt now on the Pioneer? I heard that if you use analog inputs, that you may have to increase the bass by 10db or so?
Finally, I bought 3 pairs of RCA cables from Monoprice for about $14 shipped..is that fine for the 5.1 analog? I didn't want to spend $60 at Bestbuy for RCA cables:p
Sorry for all of the questions..but I had to order the Sony, because the store didnt have any in stock, so I wont get it until next week..
thanks!
dave
thanks!
dave
Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
Post edited by krabby5 on
Most receivers won't apply bass management to multi-channel inputs. Not sure if your's is one or not. Try it and see if it makes a difference. You may need to make the +10db adjustment, in the player's setup menus.
The three pairs of Monoprice RCA cables should work just fine. I think most people use two sets of component cables for this, since they have a higher bandwidth (75 ohm, I think), normally used for video.
Good luck!Samsung HL61A750 LED DLP
Onkyo TX-SR805 receiver
Oppo BDP-83 blu ray player
Polk Audio LSi9 front speakers
Polk Audio LSiC center speaker
Sony SS-MB100H rear speakers
SVS PC12-NSD powered subwoofer
Pioneer PL-514 turntable
Logitech Harmony 628 Universal Remote -
ahh damn..I didnt even think of using component cables..I have one of those lying around..:mad:
actually the rcas I bought are 75 ohm...
heres the link
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021803&p_id=2864&seq=1&format=2Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
