Help with amp
meidschun
I recently purchased two Polk subs and need some help picking the right amp. The subs are MM1040 SVC. I plan on wiring them parallel up to a mono amp, but not sure which one. should I go with the 600.1 or the 400.1? it seems that the 400.1 would be underpowered and the 600.1 overpowered....correct me if im wong. Thanks
Post edited by meidschun on
400.1 underpowwered, 600.1 under powered but will work well, 1200.1 there ya go:rolleyes:Polk MM6501 kick panels, Eclipse cd7200mkll and SW9122 Bomb Box, Cadence A4, A7, CAP5, JL8W3V3
Theyre rated at 300 watts RMS each so youll want to get a mono amp that makes 600 watts RMS at 2 ohms mono.polkaudio sound quality competitor since 2005
and amps in that bracket are easy to source. -
Well, I ordered the 600.1 so I guess we'll see how things go.....
