how to power my RTi12s
Hi everyone, Im a very new Polk owner and new to the forum. Im sorry to say Im pretty much an audio novice so Im looking for all the help I can get.
I just got my hands on a pair of RTi12s and have heard these babies need some serious power in order to sing. These speakers are strictly for music and no home theatre. I want to get a receiver dedicated to these speakers and I plan on biamping the speakers but I had a few questions.
Can I biamp these speakers with a 2-channel receiver? how would I do that?
Also any recommendations as to what receiver or amps I should be looking at?
Basically Im hoping someone with alot more knowledge than me can point me in the right direction so I can get these puppies humming and really start to piss of the neighbors:eek:. Thanks for your help:)
Post edited by kbm on
If it's just for 2 channel music skip the reciever and get yourself a nice but affordable pre amp along with that you will need a external amp.
Do you have a budget in mind? -
haha cheaper the better as always but I figured around 2-3 hundred per amp and 500 or so for a receiver.
so I can biamp from a 2 channel receiver or preamp?
thanks for your help leroy! -
So do you want a pre-amp/amp combo or receiver/amp combo? -
I was considering the Harman Kardon 3490 as a receiver as an example of price point.
If your doing strictly 2 channel nothing else I would say skip getting a receiver and get a preamp and external amp.
A pre-amp and reciever are two different things. -
I'll second the pre-amp idea. For the money you'd probably be able to get a lot more going with a pre-amp/power amp combo, rather than an all in one receiver. The sound quality is going to be far better with seperates as well...The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
If it's strictly 2 channel music only,dump the receiver idea and go seperates,you won't be sorry.HT SYSTEM-
lsi 9's -
They are giving you good advice, receivers are a compromise to musical sound quality, they are full of devices by their design nature which degrade the signal to unacceptable levels.
Yes you can bi-amp, but many find using a quality stereo amp to their liking, or use mono-blocks to send the speaker level signal to the speaker posts.
RT1 -
Owning a pair of 12's myself,I can tell you for sure...they need a lota power to make them sing.
A separate dedicated amp. is what it takes to drive all those drivers properly.
You can find some very good entry level pre-amps. and power amps. worth the money in the Flea Market or places like Audiogon.com -
sounds like preamp is the way to go, thanks for you help guys! I really dont know to much about preamps, any recommendations as to a good preamp, or any features I should be looking for?
Any thoughts on the audiosource pre one/A as a preamp?
Using amps such as monoblocks would I be able to biamp these speakers? I was under the impression you couldnt do that with a single channel amp such as the m-block.
thanks again! -
Hey Leroy, thanks again for your help, and everyone else as well.
I was thinking about going with the audiosource pre one/A as a (2 channel) preamp as well as an external amp.
In order to set this up for biamping would I need 2 external amps or could I get away with just one somehow? Would these external amps need to both be 2 channel amps (so I could convert each L or R signal into 2 signals) or could I get away with single channel amps? How would I setup one channel coming in and 2 channels coming out of a single channel amp?
thanks again for your help everyone! -
I'll throw my .02 in on bi-amping. If you must have it you will bascially need four amps since there are four pairs of binding posts. That can be two stereo amps or four monoblocks. However IMO you should just get one good stereo amp or two good monoblocks and not worry about bi-amping.
Also I am not clear on your total budget, is that 500 for the pre/receiver and 300 each for two amps giving a total of ~1100.00? Or 500 plus 300 giving a total of 800.00?AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
Hi MADGSF, thanks for your input. I was thinking somewhere around $1000. thanks again!
You may want to look at the Rotel RC-1070/1082 for pre and a Rotel RB1080. Look for a good deal on used.Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
Pre - Nak CA-5
AMP - Adcom 555 (Main)
Main - Polk RTI8**/RTiA5
AMP - Adcom 545II (Center)
Center - Polk CSiA4**
Sub - Snell Basis 300:p......Zone 3 (Outside)
CD - Yamaha CDC-555.......Def Tech AW5500
TV - Pani TH-42PZ80U
BR - LG BD390
Monster HTS1600 Power Center
Dedicated Circuit - (2) 20amp, (1) 15amp
Ben's IC, Canare 4S11
**Dayton and Sonicap Caps with Mills Resistors** -
Exact setup I'm currently running. Great package for about $800. Forget bi- amping and get yourself a nice beefy amp.
Soon to come Rotel RB- 1092 digital amp. 500 watts x 2 @ 8 ohms. -
Welcome +1 with what these guys are recommending. Get a preamp/amp combo If you get both on Audiogon you will get more bang for your buck.
Brands to look at, Outlaw Audio, Rotel, Parasound, Sunfire, Nad, Adcom.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
thanks a bunch guys, I'll keep my eyes peeled for some rotels and do some research into some of the other brands.
thanks again! -
It's hard to beat for the price. Plus it looks BA!!Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
Pre - Nak CA-5
BR - LG BD390
