RTI4/6's Black
timmythugs
I am looking for a pair of rti4 or rti6's in black for rear surrounds. Anyone have a pair they want to part with? I live in 84770.
Post edited by timmythugs on
Have you thought about getting the new RTI A series? They can be found for about the same price if not cheaper than the older series your looking for.
Check out Audiogon and Ebay -
I did think about those. The problem is I am a matching person. This is my system thus far:
polk
rti12x2 soon to get external amp for these.
csi5
fxi5
psw505
denon avr 887
ps3
xbox 360
wii
sony kds-60a2000. By the way sony extended there warranty for the optical block fro those of you that own this until june 2010. -
I'm a matching person as well. The older rti's are becoming harder to find.
That they are...Crutchfield has had the RTi4's in cherry for 180 a pair for a while now...they just ran out a week or so ago though.
I think either Crutchfield or Amazon has the RTi6's right now for like 250 a pair or something like that. Pretty sure they're in black.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
I'll keep checking ebay. I was wanting to get a pair for around $150. Thanks for comments
I have RTi6 in LNC. 4 screw holes in bottom for stand attachment. No where to store as I am going back to a pair of refurbished LS 50's for 2 channel.
speakertweekar wrote: »if you say your a matching person then shouldent you get the rti 6 instead of rti4 ?. isnt that going to a better timbre match??
He was talking about matching as far as the cosmetics go. There's a pretty big difference in the cosmetics between the RTi's and the RTi A's.
Both the RTi4's and RTi6's would be timbre matched to his setup though.The nirvana inducer-
yhpmSDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
I have both pairs in black if still interested.I got them up on ebay but will cancel with better deal.
