lanzar optidrive 50
Systems
Systems Posts: 14,873
edited February 2003 in Car Audio & Electronics
the momo subs i want to use are the mm10 series can they handl this amp
Testing
Testing
Testing
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    these speakers are rated at 400w rms each
    but in reality you can push them to + or - 450
    i dont know what that amp is rated at
    if the rms is not higher than 500(per sub) they can handle it
    it might help to turn the gain down a little
    how many subs do you have and what are the specs on the amp?
    -Cody
