RTI 12 Speakers
irodrigues
irodrigues Posts: 2
edited January 2009 in Speakers
Hello.
Ive just purchased a new RTI 12 pair of speakers.I currently driving them on a stereo amp NAD 372 .I also have a bob carver power amp 300 RMS .When i play them thru both , the output somejow seems the same.What wud be a better bet and how can i get the best out of the speakers.
Cheers .Ivo:)
Post edited by irodrigues on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    I've noticed sometimes when adding a external amp it doesn't seem any louder but the sound quality is a lot better. Your also feeding them speakers clean power.
  • timmythugs
    timmythugs Posts: 71
    edited January 2009
    I am actually in similiar situation. I have the same speakers and I am looking for some advice on a external amp as well. I currently are running mine on a denon avr887.
  • Montoya
    Montoya Posts: 506
    edited January 2009
    I have a Emotiva XPA-5 hooked up to mine and couldn't be happier I have had a modified Carver 1.0T that was really good as well and a Rotel 2 channel amp that was also good. So far the best has been the Emotiva if you just wanted power for the two RTi-12's I would get the XPA-2. Or a nice rotel amp that at least has 100-200 watts.
  • irodrigues
    irodrigues Posts: 2
    edited January 2009
    hmm...ive connected a pair of JBLs along with the RTi12s and the NAD seems to be a bit drained for power . Will involve the Sunfire Amp to pep it a bit. Thanks fr the advice .
    Does anyone hknow why did polk actually discontinue the RTI12s,These are amazing speakers.
    ivo
  • leroyjr1
    edited January 2009
    irodrigues wrote: »
    ivo
    They came out with a newer model the RTI A 9's.
