in-wall and in-ceiling speakers
hoosier21
hoosier21 Posts: 4,413
edited January 2009 in Speakers
I got the bug to finally go ahead and install a home theater.
It will be in finished room in the basement. pretty limited on what I can do, I will be using inwalls for the front 3. I can put in two rears in the wall at the rear.
But, I was thinking of doing 7.1, if I do that, the only place for the side surrounds would be in the ceiling, so I guess I am wondering if it would sound better/best if I did the rears and side suround in a half moon type arc using 4 in ceilings.
Anyone have any experience with this type of set up? Have you heard something like this, was it good/bad/great?
Any input would be helpful.
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
Post edited by hoosier21 on
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    I'll be watching this too. I want my rears in the wall too. No wires, stands, or tall cabs. I don't like the idea of in-wall due to resonating of the walls, but for HT and you can fill the air space with blown in style insulation I think it would be fine for movies. Music is 2 channel for me any way by choice;)
    Ben
  • criverajr
    criverajr Posts: 1,675
    edited January 2009
    Hey guys, I have had rear in-walls for some time as does my brother with great results. I have used both round and square in-wall speakers. I have found that if you just use 2 cut to size mdf board, rafter size that is. Cover the inside with heavy duty roofing paper and then putting insome insulation around the speaker you will get a better sound. The aimable tweeter comes in handy also. I always run mine a little hot and the sound travels from speaker to speaker easily. I think if done right, they can work very well. You can also check dipole/bipole in-wall speakers, a little expensive but they sound great. My local dealer has some and they will be my next purchase.
    CRj
  • Eric W
    Eric W Posts: 556
    edited January 2009
    Yes, 4 in ceiling speakers as surrounds in a 7.1 would work awesome. I'd rather do that, then surround side-inwalls and surround back ceilings for consistency.
    What models/lines are you considering?
    -Eric
    -Polk Audio
  • hoosier21
    edited January 2009
    Eric Wong wrote: »
    Polk all around, not sure what line, I haven't finished looking or know how much to spend.
    Russ
  • kweb
    kweb Posts: 25
    edited January 2009
    I'm running the tc60i's in my drop ceiling for rears with great results, I just glued a thin piece of wood to the back side of the panel cut the hole put some insulation beween my joists to keep the sound from traveling. I get no vibrateing panels at all besides the fact no stands or wires exposed. ken
