repairing scratched CDs (???)
Norm Apter
Norm Apter Posts: 1,036
edited January 2009 in The Clubhouse
I heard or read (probably) somewhere that some folks use/have used auto wax to repair surface scratches on CDs. I'm wondering if anybody here has tried this method and what the results were like.
I don't even have any car wax on hand, but would be willing to pick up some to try to repair some CDs that skip if others have had luck with it.
On the other hand, if there are any other kind of solvents etc that you've tried and seem to work for renewing CDs, please let me know.
Norm
2 Ch.
Parasound Halo A23 Amp
Parasound Halo P3 Preamp
Parasound Halo T3 Tuner
Bada HD22SE tube CD Player
Magnum Dynalab Signal Sleuth
Magnum Dynalab ST-2 antenna
polkaudio Lsi9s (upgraded cross-overs)
MIT Shotgun S-3 Bi-wire Interface Speaker Cables
MIT Shotgun S-3 Interconnects (3)
IegO L70530 Power cords (3)
HT
Denon 2808ci AVR
polkaudio RTi A5s (fronts)
polkaudio RTi A1s (rears)
polkaudio Csi A6 (center)
Signal Cable Ultra Speaker Cables
Signal Cable Analog II Interconnects
Post edited by Norm Apter on
  • WilliamM2
    WilliamM2 Posts: 4,782
    edited January 2009
    I've used Meguiars plastic polish. Mine's old, at that time it was called "No.10". I'm sure they still sell something similar. Works great, as long as the scratches aren't too deep.
    I have great method of preventing scratches as well. I no longer loan out any of my CD's. Amazing results with that technique.
  • janmike
    janmike Posts: 6,146
    edited January 2009
    I like the do not lend policy. Works for me.
    Michael ;)
    NORTH of 60°
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    WilliamM2 wrote: »
    I use the same method anymore. I've lent out to many Cd's and had them come back scratched all to hell...so I no longer let people borrow Cd's. I have a huge stack of blank Cd-r's though, so if someone want's to borrow a Cd I usually just end up burning it for them.
    I've never tried using any auto/plastic wax before. I've got a few Cd's (that got lent out) that are all scratched up...and wouldn't mind fixing. I might have to give that a try sometime. Thanks for the info. :D
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • unc2701
    unc2701 Posts: 3,587
    edited January 2009
    brasso on a q-tip. takes the scratches right out.
    Backburner:Krell KAV-300i
  • daboyz
    daboyz Posts: 5,207
    edited January 2009
    Dude,you got a couple cd's I can borrow? Hell, just burn a couple and send them to me.:p:D
  • BeRad
    BeRad Posts: 736
    edited January 2009
    If the scratches aren't too bad and you have a very picky player, toothpaste can work. I have removed the "circle scratch" caused by early xbox 360's using toothpaste when I didn't have any car polish on hand. Warning though: It does make the bottom surface look foggy and kind of ugly, but it will play.
    One thing to check if it is not playing or skipping in a specific spot: Hold the cd up to a light with the label side facing the light. If you can see any "holes" of light shining through where it looks like the silver might be gone, that means you have damaged the laser plate and it is not repairable.
    Edit:
    For really really bad scratches I have had success by wet-sanding with various grit (stepping up), then cut polish, then swirl mark polish, then polishing glaze.
  • Norm Apter
    edited January 2009
    Thanks for the replies. It looks like auto polish scratch remover, Meguiars plastic polish (it seems they still sell #10 on Amazon.com) and Brasso would all work well, with toothpaste as a last resort (I'd prefer not to make my CD surfaces cloudy in the process, if possible).
    Keiko, William and Unc, could you guys let me know whether the liquids you guys applied and mentioned above respectively gave the CD/DVD surfaces a cloudy appearance?
    I don't have any of these three on hand, so I'd like to pick one of the three to purchase.
    2 Ch.
    HT
    Denon 2808ci AVR
  • comfortablycurt
    edited January 2009
    daboyz wrote: »
    Sure...no problem. You're paying for the shipping though. :p
  • WilliamM2
    edited January 2009
    The Meguiars will not cause any cloudiness.
  • thsmith
    thsmith Posts: 6,082
    edited January 2009
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2009
    SOPA
  • sucks2beme
    sucks2beme Posts: 5,612
    edited January 2009
    BeRad wrote: »
    QUOTE]
    I hate to say it, but ALL Xbox 360's do it. Son works part time at Gamestop.
    I find it hard to believe they still sell the things.
  • shack
    shack Posts: 11,154
    edited January 2009
    I buy lots of used CDs, many which have scratches ranging from very minor to very big. The error correction on my CDPs must be very good because I have yet to find a CD bad enough that it would not play or have an audible "skip". Between error "correction" and error "concealment" features on most good CDPs today I think trying to "fix "a scatched CD is a waste of time. If you do so it is only for aesthetic purposes.
  • Ricardo
    edited January 2009
    shack wrote: »
    True for CD's; Not so for Xbox games. I've also had to "repair" DVD's that did not want to play in my Toshiba HD player; it might be that its correction and concealment is not that good.
    SOPA
  • Motzart
    Motzart Posts: 1,075
    edited January 2009
    Ricardo wrote: »
    Novus products are great!
    I was using it on my Pro Built 1:24 Model Car a few years ago.
    Polished out the clear plastic nicely with a lil effort.
    Paint jobs it made em shine like glass.
    It's also worked nice on Plexiglass.
    So I have had good experience with this stuff and it's not expensive!
    I'll hafta see what it does for CD's!!
    Yamaha RX-A710 90Watt 7.1
    Mains: RTi A1's Center: CS150 Sats: RT15i's Sub: Velodyne DPS-10
    Music CD: Sony CDP-CE375 5 Disk
    HD TV: Vizio 42" LCD 1080p E420VO
    Blu-Ray: Sony BDP-S350
    DVD: Sony DVP-NC665P 5 Disk
    AV Rack: Sanus Euro EFAB-II Audio Base x2 EFAS-II Audio Expansion Shelf x4
    Cables Used: Monster Cable HPD Sony HDMI DLCHE18W
    Phones: Sennheiser HD280 Pro
  • Ricardo
    edited January 2009
    Motzart wrote: »
    I use it for my Clearaudio acrylic turntable. Works great.
    (See? You don't get smashed with EVERY post....just the annoying ones ;))
    SOPA
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    Ben
  • John30_30
    John30_30 Posts: 1,024
    edited January 2009
    BeRad wrote: »
    Edit:
    Thumbs-up on this. That's the pro method.
  • Jstas
    Jstas Posts: 14,845
    edited January 2009
    I got one of these:
    http://www.madcatz.com/Default.asp?Page=135&CategoryImg=Universal_Accessories
    Works like a champ! Took quite a few passes to get a really bad circle scratch out of Forza 2 but it got about 90% of the scratch out without unbalancing the disc or digging in too deep. It did make it a bit foggy but I think it was due to heat buildup. I was getting a tad impatient and not waiting long enough between buffing runs.
    But as for the other DVD's and CD's, works great. Any time I have a problem with a disc, even a rental, a pass or two in that little jobby works wonders! Best part is, I don't even have to break a sweat!
    Expert Moron Extraordinaire
  • Motzart
    edited January 2009
    Ricardo wrote: »
    I've seen some lot worse than any of mine....nothing ever said...least not extreme.
    Hey man whatever......
