Bi-wiring LSi7s witih Adcom GFA 535
dcacc
dcacc Posts: 45
edited January 2009 in Speakers
I just bought a used Adcom GFA 535 and love its sound. It has connections for two sets of speakers. Can I bi-amp a single pair of LSi7s by using both A and B connections? Will I see any advantage from doing this?
Post edited by dcacc on
    heiney9 Posts: 25,432
    edited January 2009
    dcacc wrote: »
    You won't see an advantage. But go ahead and try it. I can't rememner how the the speaker switches are wired. That will be the limiting factor.
    I believe the speaker switches for "a" and "b" when engaged are in series. Bi-amping while being hooked in series is not an advantage. In theory the resistance is higher meaning you may not get the full potential from the amp.
  • dcacc
    dcacc Posts: 45
    edited January 2009
    What about bi-amping using both the Adcom and my Onkyo 805? I'm curious to try this but I don't know enough about electronics to know if it's going to do any harm. Or would the worst case be that it just doesn't sound very good?
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    dcacc wrote: »
    Bi-amping with two different sources is not recommended.
  • curved
    curved Posts: 664
    edited January 2009
    Exactly what Lee said.....if you had a gain control on the amp it would be fine. The problem though however, is the gain could be way different causing either bass/treble to be off quite a bit.
    Living Room:....................[HTML] [/HTML] Zone 2 (Workout Room):
    AVR - Yamaha RX-V757......JBL 4312 Pro Monitors
    Pre - Nak CA-5
    AMP - Adcom 555 (Main)
    Main - Polk RTI8**/RTiA5
    AMP - Adcom 545II (Center)
    Center - Polk CSiA4**
    Sub - Snell Basis 300:p......Zone 3 (Outside)
    CD - Yamaha CDC-555.......Def Tech AW5500
    TV - Pani TH-42PZ80U
    BR - LG BD390
    Monster HTS1600 Power Center
    Dedicated Circuit - (2) 20amp, (1) 15amp
    Ben's IC, Canare 4S11
    **Dayton and Sonicap Caps with Mills Resistors**
