how to mount center channel speaker?
![mewisemagic](https://w3.vanillicon.com/375a5025d1ac8e278d94c9c57bfb2326_100.png)
mewisemagic
i want to add a center ch.speaker above my hdtv, whats the best way?my tv is about 18" from the wall is there a way too wall mount or mount too the tv itself?
Post edited by mewisemagic on
I don't have direct experience with this, but there is what looks like a good option from Audio Advisors. I have used them for other audio components and add-ons.
Here is the link:
http://www.audioadvisor.com/prodinfo.asp?number=OMCCH1 -
Either a shelf or a center channel bracket such as this one:
http://www.crutchfield.com/p_121BT15B/B-Tech-BT15-Black.html?search=center+wall+mount&tp=586-Eric
-Polk Audio -
ok, thanks . that may work:)
GregC, I have a Samsung LN46a630 and am getting a cs2, do you think that bracket would work. That is exactly how I was imagining setting the center, just worried about the weight of the cs2 and that glass edge on the tv.....
It works perfect for the CSi3.
As long as you are on studs or use a good set of wall anchors you should be fine.
Dude, is that a Bhudda statue with a Chia-head?
Ch-Ch-Ch-Ch-Chia!Do you hear that buzzing noise? -
Hi,
Found your post about mounting a centre speaker to the wall using the crutchfield B-Tech BT15 mount .Eric could you tell me if the crutchfield B-Tech BT77 wall speaker mounts would be ok to mount a set of RT25i ,s bookshelf speakers to the walls for a home theather setup like what Erik has done, or would you recommend something else.
Peter -
Hi,
Peter
I'm not Eric...
but in looking at the specs for the RT25i, it is about the size of an RTi4 - which I also had mounted up on my fronts using the B-Tech BT-77 - it should work perfect for the RT25i.
The speakers you see in the picture I linked are the RTiA3s - bigger and heavier than the RT25i.
Erik
It's crazy -- I had the exact same question and when I posted it I got no response...
The problem with the L-shaped brackets is they kept the speaker too close to the wall -- I have RPTV (Mits 73") and the front of the screen sits 18.5" from the wall. I eventually went with a CRT tv wall mount from vuepoint:
http://www.vuepointav.com/products/crt-mounts/tvmb
It looks great -- I mounted it so the top of the "lip" at the front of the shelf is flush with the top of my TV -- you can barely see it from any angle, and it's made to hold upt a 60-pound TV so it's ROCK solid holding my CSi A6... -
well i had to go another route, by wife threw a fit when i said i wanted too mount a speaker over the tv:rolleyes:. so i ended up putting it below in the entertainment center:(. still sounds better though
Well hey whatever works right, at least you found a place for it!
I ended up just buying a couple black brackets from Home Depot, **** them to the wall (making sure to hit a stud), and resting my CSi A6 right on them. It works perfectly, looks great, and i paid practically nothing for those brackets!
Man you guys need to take charge of your woman!!! lol
Maybe i'm just lucky in that aspect, my fiancee (been with her almost 7yrs now) doesn't tell me what i can and can't do..:p -
Here is the link:
This is what I am currently using on my Sony 60" Projection HDTV and it works great!Main System:
Sony DA6400ES Receiver, Sony BDPS500ES Blu-Ray
Denon DRS810 3 Head Cassette Deck, Sony KDA60ES3000 60" HDTV ,Emotiva XPA 2 Powering the A9's, Monster Power HDP 2550, Monster Power AVS 2000 SS Voltage Stabilizer, Direct TV HDTV Receiver,Polk RTIA9 Towers:D, Polk CSIA4 Center:D, Klipsch RC51 Surrounds, SVS PB13 Ultra Sub, Monster Cables HDMI 1000 Cables, Monster Cables M Series Speaker Cables -
I use a Peerless component mount. Works well because you can bolt the bracket to studs, and then slide the legs where you need them. Also adjustable for depth. Price has went up though, I paid $24 delivered a year and a half ago:
http://www.buy.com/prod/peerless-pm600-multi-mount-vcr-dvd-wall-mount-kit-45-lb-peerless-pm600/q/loc/111/202070144.html -
Man! I wish I had known about this before -- or the PS200, also from Peerless:
http://www.peerlessmounts.com/dyn/Products/BrowseProduct.aspx/tn/3/u/t/categoryID/392
My TV-mount solution worked pretty well, but either of these would probably have been easier, and the PM600 is adjustable for depth up to 19.5", and the PS200 up to 23"! OH well, guess there's no use to complain now... -
Hey Erik what Component stand you using there in the middle??
Walker Edison Everest Black Glass Multilevel from Stands and Mounts.
It is in piece parts - so you can mix the parts to be two, three, or four levels with the different heights at whatever tier you want them to be.
The sides enclosures are from Sorice.com.
