Subwoofer without LFE Connector - HELP
javygonx
Hi:
My CerwinVega Sub does not has the single LFE Connector, but it has 2 Inputs RCA (Left/Right), and 2 Outputs (Left/Right).
I connect only a Digital Coax RCA Sub Cable to the Left Input of my sub to my PreAmp Out of the Receiver. But if I use an "Y" Cable (2 male, 1 female) connector so I can fill the (L/R) input of the subwoofer amp to the preout of my receiver, do it will sound better or its the same thing?!
Panasonic 65" Plasma
Pioneer SC81
PS4 BluRay / Memorex BD-Player
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Monster Power HtS 1600 Power Line Filter/Conditioner
Pioneer SC81
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Post edited by javygonx on
Yes, you can connect to either the left or right input of the subwoofer or you can use the Y connecter to both inputs If you'd like. It makes no difference either way...
ThanksPanasonic 65" Plasma
Pioneer SC81
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Monster Power HtS 1600 Power Line Filter/Conditioner -
Yup, then turn the crossover/low pass knob as high as it will go.-Eric
-Polk Audio
