Re post.....In-Ceiling/Wall Speaker System
Hello...first time to this site.
I am finishing my basement and decided to go with in/wall and in/ceiling speakers. I want to use as a dual stereo/surround system.
I have decided to go with Polk rc85i for the front wall speakers and Polk rc80i for the rear speakers. I am going to go with the Polk psw111 for a sub.
My question is what is acceptable for a center speaker? I am on a budget and will not spend $650 for the Polk lci-c. Can I just get another rc85i and use as a center? Also, would these sound matched as all the same brand?
Any help would be appreciated as this will be the first stereo system that I have purchased? Perhaps, I am going down the wrong path with in ceiling/wall speakers but I really like the look.
Thanks.....
Thanks.....
Post edited by sschmidt5 on
... My question is what is acceptable for a center speaker? I am on a budget and will not spend $650 for the Polk lci-c. Can I just get another rc85i and use as a center? Also, would these sound matched as all the same brand? ...
I am hoping to do the same thing myself at some point in 2009 (delayed because of market losses in 2008), and had expected to use the same solution.
Oh ... and welcome to Club Polk!Alea jacta est! -
Your best bet would be to get a cs2 or another rc85i you really are going to like the rc series my brother-inlaw went with these and loves em. I wouldn't get an lci series center it wouldn't be a good match.
Your best bet would be to get a cs2 or another rc85i you really are going to like the rc series my brother-inlaw went with these and loves em. I wouldn't get an lci series center it wouldn't be a good match.Alea jacta est!
I have had my RC85I's for a few months now and they are awesome. Even for music if you are listening to 5.1 vs 2 channel. They are quite warm sounding with very crisp highs. You will appreciate the directional tweeters.
Thanks for all of the quick and excellent replies. I am going to purchase another rc85i for the center per your suggestions.
I truly appreciate the feedback.
