need passive radiator replacement
twanto
twanto Posts: 18
edited January 2009 in DIY, Mods & Tweaks
I have a passive radiator (drone cone) that I need to replace on an old sub-woofer. I'm having trouble finding one that is cheap (as the original part was cheap). The opening is 6 7/8" but including the part of the surround that is glued to the frame, it is 8". I do not know how these things are typically measured. Does anyone have any advice on replacing this part? It seems like it should be cheap and easy, but I just can't find the part.
Post edited by twanto on
  • rallyshark
    rallyshark Posts: 417
    edited January 2009
    Parts Express has a few and under $20 for the dayton 8", and it lists detailed dimentions. Madisound has some to if you wanna spend more:rolleyes: I haven't personally used any of them, but alot of people seem to think the daytons are a good bang for the buck, and they are "tunable". I hope that helps:D
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • twanto
    twanto Posts: 18
    edited January 2009
    rallyshark wrote: »
    Thanks for the tip. Since the entire 5.1 system cost $65 it probably isn't worth $20 to buy a replacement. It's for a computer. I should probably just buy a decent 2.1 system.
