What's a good setup for 3.1
FittyFieFo
Hey guys, I'm having troubles figuring out what setup to use. I normally used 2.1 Stereo on my receiver. I recently purchased a Csi5, now I'm having trouble picking a set up. My subwoofer doesn't seem to be working, but when I do the calibration test with the optimizer mic, it receives a good signal for the subwoofer. When I watch a movie or play music, the subwoofer doesn't seem to produce any bass.
It did work when I had 2 RTi 10's (2.1 Stereo).
Any solutions? Do I use 7.1 Stereo???
Any help will be helpful, thanks guys!
Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables
Post edited by FittyFieFo on
do you have the subwoofer setup in the receiver as lfe+main or both....depends what your receiver calls it.
for the Option "LFE/Bass Out" It's set on SWFR.
The options I have are
"SWFR" , "FRONT", "BOTH"Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
Pre-Amp: Marantz AV7005 | Amp: Emotiva XPA-5 | Speaker wires: Signal Cables | Interconnects: Signal Cables -
I am currently using a 3.1 setup. On my Denon reciever I have it set to 5.1 and my subwoofer engages. Not sure if that helps or whether that is even the reason why your Subwoofer isnt working but mine is working.
Zsolt -
I'm trying everything, it just doesn't seem to work!Samsung LN52A850 (52" 1080P LCD TV) | RTi A9's (Fronts) | Csi A6(Center) | FXi A6 (Rear Surrounds) | SVS PB12-NSD (Sub) | Oppo BDP-103 | Panamax M5300-PM
I would try using 5.1 on your receiver. I don't think most receivers have a 3.1 setting. I assume you have the sub connected to the LFE output on your receiver? That should definitely work with movies. How is your DVD player's audio connected to the receiver? I would recommend using any digital output if you can. Most receivers will automatically select the correct surround sound mode if it's digital.
