LSi System Suggestions Please
Murray1
Murray1 Posts: 193
edited January 2009 in Speakers
Considering LSi 9's for the front, LSi C, and LSi 7's for surround rears. Also looking at Onkyo 806(130W/channel) to drive the rears and an Emotiva XPA 3to drive the fronts and center. If anyone already has this configuration I would like to hear your comments. One of my questions is if the 806(130W) will drive the rears sufficiently. Application will be mostly HT. Since it appears the Emo XPA 3 outputs more power than the XPA 5, I am leaning towards the 3 - opinions? Lastly, wondering if I can hold off initially on the amp and operate the system at normal movie volume and not damage speakers or receiver. Understand the amp is the way to go, but it would be nice to pick up the amp after the checking account recovers a bit.
Post edited by Murray1 on
  • Face
    Face Posts: 14,340
    edited January 2009
    Don't crank the volume too much and make sure the receiver is set for 4 ohms, you'll be fine for a while.
    Once you get a amp for your front end, your 806 should have no problem powering the rears.
  • Pepi28
    Pepi28 Posts: 248
    edited January 2009
    ^+1. What face said.
    58" Samsung Plasma (on wall)(calibrated)
    LSi15's front (modded xo's)
    LSic center
    LSiFX's sides
    LSi7's rears
    Sunfire Sig. 600 amp for 15's
    Sunfire Sig. Cinema for C,S&R
    Sony ES 3000 pre/pro
    SVS 2039 PC Plus sub 12.3 (16hz tune)
    PS3
    Wii
    Signal and Audioquest ic's
    12 awg monster speaker-cable (bi-wired)
    Belkin PF60 power conditioner
    Monster power conditioner for sub
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2009
    Murray1 wrote: »
    I think you have that backwards. The XPA-3 and XPA-5 are almost the same thing except for the # of channels. But the XPA-5 has more power to offer-at least according to the listed specs (when comparing the same # of speakers being driven at a time).
    XPA-3
    # 200 watts RMS/channel into 8 ohms, all channels driven
    * 3 channels - 8 ohm = 200 watts per channel
    * 2 channels - 8 ohm = 225 watts per channel
    * 1 channels - 8 ohm = 300 watts per channel
    # 4 ohm rating:
    * 3 channels - 4 ohm = 300 watts per channel
    * 2 channels - 4 ohm = 400 watts per channel
    * 1 channels - 4 ohm = 500 watts per channel
    XPA-5
    * 5 channels - 8 ohm = 200 watts per channel
    * 4 channels - 8 ohm = 230 watts per channel
    * 3 channels - 8 ohm = 250 watts per channel
    * 2 channels - 8 ohm = 275 watts per channel
    * 1 channel - 8 ohm = 300 watts per channel
    # 4 ohm rating:
    * 5 channels - 4 ohm = 350 watts per channel
    * 4 channels - 4 ohm = 375 watts per channel
    * 3 channels - 4 ohm = 400 watts per channel
    * 2 channels - 4 ohm = 450 watts per channel
    * 1 channel - 4 ohms = 500 watts per channel
    ____________________
    Pool: Atrium 60's/45's
  • Fatwalnut
    Fatwalnut Posts: 54
    edited January 2009
    you need to make sure that the center and surround channels are designed to handle 4 ohm speakers. Alot of receivers can only handle 6 or 8 ohm on these channels. You could damage you receiver. Check the manual of the one you are buying. Don't go by the salesman, as he is only trying to sell you something. Good luck.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2009
    The most important factor is that he could damage his SPEAKERS!!!
    Just buy a nice beefy separate 5-7 channel amp & be done with it. Otherwise get 8ohm speakers.
    Fatwalnut wrote: »
  • Hilbert
    Hilbert Posts: 316
    edited January 2009
    "Considering LSi 9's for the front, LSi C, and LSi 7's for surround rears."
    I have this set of speakers being driven by an xpa 5 and it sounds terrific, imo. So my advice is the 5 and stop worrying about amplification. Worry instead about paying for it. :)
    Since your interests are mostly HT, have you considered RTi As? Haven't heard them myself but there seems to be consensus they are relatively easy to drive and very good for HT, maybe better than LSis for that app.
    Pair of A9s on Polk Direct now for $900 + tax and shipping. Roughly what 2 LSi9s would cost new from Crutchfield.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited January 2009
    Hilbert wrote: »
    I also have the same LSi set and an XPA-5 as well. You can likely save some money by getting the 5 to power all the LSi's, and look at a 706, or 606 for the processing. (depending on how cheap you can get the Onks for) Or, for ~ the same money as the 6/706, you can get one of the new Emo pre/pros,(when they arrive) and skip the AVR all together.
    If you already have a receiver with pre-outs, you can run the amp off it, to bide time until your account recovers. You might decide you didn't need the upgrade after all. (but I suspect you're after the new audio formats...):D
  • doug lang
    doug lang Posts: 261
    edited January 2009
    You know this Lsi 4ohm with the 806 onkyo receiver or others is asked again and again. Almost to the point of saying go try it let us know what possibly may or may not happen. Don't get me wrong all questions are important and that is how we all have learned. i just think this has been beaten to a dead horse.
    The lsi are fine speakers and as we all know they are 4ohm. hungry. As surgested read up on these units before you purchase. Most sales people will sell you anything for a buck. And lastly low volume with the lsi series may not be the way to go. You will want to get a taste of the lsi speakers.
    Oppo bdp 93 Blue Ray
    Integra DTR-80-2
    Polk LSi9s (mains)
    Polk LSiC (center)
    Polk LSiFXs (surrounds)
    Sub SVS 20-39+
    Samsung 60" Led 3-d
    Blue Jean Cables
  • Murray1
    Murray1 Posts: 193
    edited January 2009
    Hilbert wrote: »
    Never considered RTi family but am open to suggestions. I am not into super high volume anything so starting to wonder if LSi's are for me. What RTi configuration would be good for a 5.1 surround system. Thanks everyone for your input.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    Murray1 wrote: »
    Rti A9/ Rti a5 fronts
    Csi A6 center
    Fxi a6/ rti a3 rears
  • cfrizz
    edited January 2009
    Sigh. The LSI's are good for BOTH it is simply going to take more power to get them to the same volume that would be the equivalent of the RTI series. Because they are 4ohm speakers. But they will sound a whole lot better for both. But most especially for music.
    It is NOT about loud volume, it is about giving the speakers what they need to operate to their full potential. And most receivers can't do it for the LSI's.
    All speakers sound better with separate amplification, with 8ohm speakers, an amp is optionial. With 4ohms speakers like the LSI's it's really not, unless you want to sit on top of them to hear them or push them without what they need & risk damage to them.
    Murray1 wrote: »
  • daboyz
    daboyz Posts: 5,207
    edited January 2009
    I you are more of a HT kinda person then the Rti's will do you beautifully. With all due respect to Leroy,you can go the used route and get Rti8's,Csi5etc. and have a helluva HT for a very good price. You won't really have to worry about separate amplification but it definitely wouldn't hurt. The Lsi's would definitely need an amp. It's not about the volume but the power.
  • zede
    zede Posts: 2
    edited January 2009
    There's a pair of LSi7s on ebay for $189. One speaker has a damaged tweeter, but the sellers states that the other works fine. As the seller notes, this could be a good fron center or rear center on the cheap:
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=190279400630
    PS. I don't know the seller. Just thought I'd put this out there.
  • MSALLA
    MSALLA Posts: 1,602
    edited January 2009
    IMHO it is not worth spending the extra money on the LSi's if you are not goin to run them off of something with the amps to properly drive them. When I added amps to my system it sounded like a got new speakers. The RTi line has a great sound and will run off any AVR with no problems. This is just my 2 cents. Do a search on here. This topic has been around for a long time.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • be83663
    be83663 Posts: 192
    edited January 2009
    Stay with Onkyo 806 and LSi setup. They will sound nice.
    When you have enough money, then go for XPA-3. :)
  • Murray1
    Murray1 Posts: 193
    edited January 2009
    MSALLA wrote: »
    Went to frys today to demo RTI a9's. Difficult to compare to LSi 9's because both sets of speakers were driven off receivers only. Seemed like LSi 9's had more depth to their sound but again no amp was connected. Someone mentioned RTi's may be better for HT. Any ideas why? LSi 9's sounded very good without an amp so am wondering how they fare against the a9's when an amp is connected.
  • lumpy
    lumpy Posts: 113
    edited January 2009
    I have just finished putting together this set up. I am driving the center and the 9's with sepperates and the 7's with a yamaha 863 and a powered sub added in. I am currently saving for the lsifx's at which point I plan to moove the 7's to be additional fronts.
    I think that this set up sounds great. the 9's sound great but deffinetly needed the 200+ wpc amp.
    right now the 9's are set up about 2.5 feet off the floor and need to come up another foot to sound better though.
    I listen to all music forms - mostly clasical. pink floyd Dark side and crystal method leagon of boom also kicks some but.
    my vote would be to get the Lsi's and save for the amps. I've started with budget amps and will eventually move up to better ones. A man has to have a hobby other than fishing.
    pop
    media room: Lsi25 mains driven by an audiosource amp300, LSi9's driven by another amp300, LsiC drivin by an audiosourcAmp200, Lsi7 rear channels driven by receiver - Yamaha 863, Panamax 5300, epson 6100 w/ 106" elite cinatension2 screen, HPz555 media center, oppo 980, techniques SLbd3 turntable,xbox and ps3,
    living room: VM30 mains driven by a niles 2125, VM20 center and VM10 surrounds, velodyne dsp10, yamaha rxv661, cambridge audio dvd89, panamax5300, philips 42" plasma
  • Face
    Face Posts: 14,340
    edited January 2009
    lumpy wrote: »
    Why?
  • cfrizz
    edited January 2009
    Welcome to Club Polk Lumpy. Sounds like you got a smoking set up. Congrats!
  • lumpy
    lumpy Posts: 113
    edited January 2009
    Face wrote: »
    Why?
    A. why not - I have only been at this for about a year and a half. do you have any advise - please share.
    B. my rxv863 can output an additional front set of channels that provide what they term diagonal lift. I was using this with my 661 and liked the ability to bring the vocals more to the center of the screen. I find that this helps with an 106" screen where the center chanel is placed just below the screen.
    C. I do not have a place for rear channels - therefore LsiFx
    pop
  • Bass_Pedal
    Bass_Pedal Posts: 196
    edited January 2009
    I owned a pair of RTiA7s for about three months. I had them runing off an Adcom GFA 545 amp. For HT, they were awesome. The bass was crazy, impressive slam. Action movies in particular blew me away. Unfortunately my usage is about 85% music 15% HT so after much deliberation I sold them and got a pair of Lsi9s. Since then I have purchased an LsiC. IMO the Lsi's are in a different league for music than the RTi's. For HT, I have to say I prefer the RTi's. The fact that they are easier to drive should sway you more in that direction. A full suite of RTi's would be well served by that 806 receiver.
    Mains - Vienna Acoustics Mozart Grand
    Subs - Rel T5 x 2
    Amplification - Bryston 3b cubed
    Pre Amp - Marantz Sc11-1
    SACD - Marantz Sa11-1
    Stream - Cambridge Audio CXN v2
    Dac - Marantz Dac-1
    TT - Pro-Ject RPM 9.1 w/ Ortofon 2M Black Cartidge
    Phono Stage - Project Tube box DS
  • Igo
    Igo Posts: 411
    edited January 2009
    leroyjr1 wrote: »
    ...../ Rti a5 fronts
    Csi A6 center
    Fxi a6/...... rears
    I have an earlier generation of this set up and can't sit in the room with it at volume. It's a great music set up as well.
    ...Link to my System Showcase...
    "ES - Kind'a simple but I like it"
    Sony ES STR-DA4300ES 7.1
    Sony ES SACD SCD-C2000ES
    Sony 400 Disc CD CDP-CX455
    Infinity BU-2 Sub-Woofer
    Polk Audio RT800i Towers
    Polk Audio CS400i Center
    Polk Audio FXiA6 Surrounds
    Sennheiser HD 280 Pro Headphones
    DH-Labs T-14 Speaker Cables
    Panamax Max 500 DBS Line Conditioner
    Panasonic TH-50PZ85U 50'-Plasma
    Play Station III - BluRay
    Logitech Harmony 550 Remote
    Logitech diNovo Mini Keyboard
  • timmythugs
    timmythugs Posts: 71
    edited January 2009
    I have the hookup. PM me for details. Want the best but dont want the price?
  • Igo
    Igo Posts: 411
    edited January 2009
    xcapri79 wrote: »
    I think you need to decide whether you are going with the RTi series which sounds great or the LSi series which is more expensive but prehaps sounds even better, IMHO. The LSi9's are awesome with an amp but so apparently is the RTiA9.
    It is strongly recommended with the LSi25's, 15's, 9's and C's to use an external amp with at least 4 ohm 200 wpc rating. The LSi7's will benefit from an external amp but should run on your Onkyo 806 just fine. Many recommend an external amp for the RTiA9 or A7 but it is not as important as with the LSi's since the RTi's have an 8 ohm rating. Pretty much any decent receiver will power the A5 and lower RTi's just fine.
    You will have to decide for yourself based on what you hear. Many find that the LSi's have a clearer more refined sound which is important for classical music for example. To your ears, what is the cost/benefits of each?
    Both will do well in HT, glass breaking is a sensation with LSi's, I know that for sure.
    To many, aesthetics are important too. How do you want your system to look relative to your room and furnishings? Is this a factor? It is for many wives.
    It's like trying to decide between platinum and gold. Whatever you end up with is pretty nice.
    The A5 with a sub is probably the most musical set up in the Rti family. Two efficient and strong mid drivers with with a sub bringing up all the bottom end. This is speculation but I don't think 3 7 inch low frequency drivers tied to a 130wpc receiver OR a 200wpc amp will stay with a 150 watt amp on a dedicated 10 or 12 inch sub.
  • Igo
    Igo Posts: 411
    edited January 2009
    lumpy wrote: »
    This sounds like a whole lot of really bad math to me. Tweeters 2 feet above the listening position? different sounding amps running each speaker set? TWO sets of fronts? RT fronts and LSI rears? Stick around and read before you spend the bucks my friend. Of coarse I might just be reading this wrong too.
  • lumpy
    lumpy Posts: 113
    edited January 2009
    Igo wrote: »
    I guess so -
    to clarify - all Lsi + all fronts 2.5 feet above the floor and driven with one brand of amp. 7's as rears via the receiver.
    http://www.edhelper.com/math.htm?gclid=COWksI-_m5gCFQG7Ggod03o9mw
    I am sorry that your listening position is 1/2 foot off the floor.
    pop
