Preferences on Line-Level Connections
GregoryOrme
GregoryOrme Posts: 25
I am trying to connect the pre-outs on an Onkyo TX-SR706 AV Receiver to a PolkAudio DSW 500 subwoofer as well as all three inputs on an Emotiva XPA-3. The plan is that the Emotiva will power the fronts (RTi A9s) and center (CSi A6) channel, and the Onkyo will power the surrounds (FXi A6s).
I want to use something that will, if possible, help minimize any hum since the cabinet that will house these will not allow for any significant separation of these cables and the power cords. I'm not a superaudiophile by any means, but I would like something that would be comparable to the rest of the system; that is, not a thrift-store special but nothing exotic, either.
The subwoofer line will have to be 10-12 feet long to get it where I want it. The other connections will be just long enough to connect the Onkyo and Emotiva.
Thanks in advance for reading and for any advice you may give.
Gregory
Power Amp: Emotiva XPA-3
Fronts: PolkAudio RTi A9 Canare 4S11/Vampire Wire B12
Center: PolkAudio CSi A6 Canare 4S11/Vampire Wire B12
Surrounds: PolkAudio FXi A6
Rear: Polk Audio RTi A3
Sub: PolkAudio DSW Pro 500
Post edited by GregoryOrme on
  • sandworms
    sandworms Posts: 1,043
    edited January 2009
    go to monoprice or bluejeans.com they have great prices and quality I got my sub cable from monoprice at 25' and it's a beautiful thing
    Samsung pn64f8500
    Sonus faber venere 2.5
    Sf venere center
    Oppo 105d
    Squeezebox touch
    Parasound hca1500a
    Apc power filter
    Audioquest cables asst
    Polk rtia3 SB
    Polk fxia6 sl,sr
    Dual hsu vtf3 mk3
  • GregoryOrme
    edited January 2009
    Thank you for the advice, sandworms!
    Gregory
