RTA 12 or newer RT2000i-Need advice?
Familycat
Familycat Posts: 16
edited May 2009 in Vintage Speakers
Looking to upgrade my vintage RTA 12's and have a line on RT2000i's. Will thy sound better? I would like a little better bass and thought the 2000's with the powered sub would help. I am concerned they might not play loud enough with only one driver. Help.
Rick
  • mark g. nelson
    mark g. nelson Posts: 134
    edited January 2009
    Oh they will play plenty loud. The powered tower is not the in thing but if set up properly can sound damn good. The single driver will limit your mids but if set up and dialed in right will sound amazing. The 2000's are very efficient but they sound even better with 200 watts or more.
  • Familycat
    Familycat Posts: 16
    edited January 2009
    Thanks for the reply. Are you saying they will sound better than my old RTA's? If so that is is good. I have a Pioneer elite reciever with 140 wpc. Is 140 enough power to push the 2000's?
    Rick
    F1nut Posts: 52,343
    edited January 2009
    I would suggest that you are not getting the best out of your RTA's with a receiver.
  • mark g. nelson
    edited January 2009
    I have owned several PE receivers and they match up well with the 2000's. I guess you are running a 94 or new 07, if you have 140 watt. I was running my 54 before I got some amps to use with it.It will sound great. But I would agree with F1nut that receiver power is not giving you all the perks of either speaker.
    If you are staying with receiver only the 2000's with the powered section are going to be an easier load on your receiver in my opinion.
  • Familycat
    Familycat Posts: 16
    edited January 2009
    Makes sense. I am running a PE 74. Speaker are CS400i for center and FX500i for surrounds. I have an old pair of JBL L100 in a second room for the 2 other channels but really hurts sounds if you try to push very hard. I have read some reviews that complain that the mid section is a little weak on the 2000's. I also read on Polk's website that the 2000 was a RT35i mounted on a sub. It did not make me feel very good. I want to like these speakers just don't want to make a mistake.
    Rick
  • dmata10
    dmata10 Posts: 4
    edited May 2009
    You still looking for a pair of RT2000i's?
