Need some advice...
Joker1975
Joker1975 Posts: 3
Hello all,
I am brand new to the forum I find this forum to be very informative.
I recently upgraded my front speakers with the LSi15's so now my configuration is:
LSi15's up front
CS400i Center
RT25i rears
PSW450 Sub.
I just came across the steal of a lifetime on a Sony 3400ES receiver ($500 brand new) and now after a little reading around I notice that the LSi15's are 4 ohm speakers and the rest of my speakers are nominal 8 - minimum 4 ohm.
I read that the 3400ES has a 4/8 ohm switching mode.
My question is this...
Which setting should I run my receiver on 4/8? I guess that if it is on 8 then the LSi15 will be sucking the life out of the receiver and it may run hot.
2nd question is - if I run on 4 ohm, is there a risk of hurting the other speakers? Or will they run loud which I can control the levels - not a big deal.
I understand that I could get a separate Amp but I do not think I am that high end yet - nor do I have the cash.
Will this system run decently or perhaps do I look to return the LSi15's and grab a decent 8ohm speaker like the RTiA9's?
I would really appreciate any help.
Thanks alot.
JD
Post edited by Joker1975 on
  • Jim Shearer
    Jim Shearer Posts: 369
    edited January 2009
    Welcome to CP!
    If you only listen at low levels, the the Sony AVR will probably manage. But you really won't be able to make the Lsi-15's sing. Can you live w/ it for a while & pick up a used amp in a few months?
    Cheers, Jim
    A day without music is like a day without food.
  • Joker1975
    Joker1975 Posts: 3
    edited January 2009
    Well - We listen to 60/40 movies to music so I think it shouldn't be that much of an issue but form time to time we have a coupe bevies and we turn it up a notch or three...
    That said I could get an amp at some point but then do I need to upgrade my center and surround speakers as well?
    I am mainly wondering if I should have my receiver on 4 or 8 ohms and if it will cause damage to the 8 ohm speaks running on 4 ohms?
  • jeeper_nick
    jeeper_nick Posts: 27
    edited January 2009
    Hey, Joker - I'm in the same boat - I plan on running all Lc-series in-walls which are 4ohm rated mated to a Onkyo TX-SR876 which outputs at 6/8 ohm. The solution to my problem can be solved for about $4-600 in the form of multi-channel amps from either Outlaw or Emotiva. Personally, I'm leaning towards this monster: http://emotiva.com/upa7.shtm
    Best of luck with your set-up!
    Joker1975 wrote: »
    JD
    Coming Soon: The GregorPlex II Cinema
    Sanyo PLV-Z2000 Projector
    106" HDTV Formatted Electric-drop screen
    50" Samsung PN50A450
    Onkyo TX-SR876
    Emotiva UPA-7 Amplifier
    PlayStation3
    Monster HTS 3600 mkII
    *undetermined upconvert DVD player*
    Polk LC265i Fronts
    Polk LCiC Front Center
    Polk LC80i Rears
  • Jim Shearer
    edited January 2009
    Joker,
    Set the AVR to 4 ohms. That drops the rail voltage to keep the output transistors in their safe operating area (SOA.) It will decrease your available output the surround speakers, but that's the price you pay for keeping it safe. :o
    Cheers, Jim
  • Joker1975
    Joker1975 Posts: 3
    edited January 2009
    Now I am starting to think it may just be easier to have the same impedance across my whole system.
    What are the better speaker for home theater?
    The LSi15's or the RTiA9's?
  • apphd
    apphd Posts: 1,514
    edited January 2009
    Joker1975 wrote: »
    While this doesn't exactly answer your question hope it helps. I would say the LSi15 would be classified as more of a dual purpose with the emphasis on music. Where as the RTaA9's would be more of a HT speaker with OK to very good musical capabilities for most people. Your best bet IMO would be to find a place you can listen to both speakers being driven by something close to the Sony. In any case try to make sure the speakers are driven by the same source during the audition. Then decide what YOU like best for SQ. Then if is the LSi you'll have to decide if an amp fits into your budget sometime in the near future. Because if you go with the LSi with your occasional listening taste of "form time to time we have a coupe bevies and we turn it up a notch or three..." you will more than likely need the amp.
    As far as the 8 ohm speakers in the mix, you will not hurt them with the switch in the 4 ohm position as far as I know. Like Jim S said you will only drop what is available to the surrounds a little. Someone please correct this if it is wrong.
