Spectrum Analyzer
joeparaski
joeparaski Posts: 1,865
edited January 2009 in DIY, Mods & Tweaks
I've been looking into these things as a way to "tweak" my system to improve the sound. These are a couple of the units I'm looking at:
http://www.samsontech.com/products/productpage.cfm?prodID=1735
and
http://www.phonic.com/en/testers/paa3.html
I was wondering if any of you folks have experience using these tools and if there are any other units I should be considering.
I'm assuming that the terms "Spectrum Analyzer" and "Real Time Analyzer" mean the same thing.
Any comments or suggestions would be appreciated.
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • george daniel
    george daniel Posts: 12,096
    edited January 2009
    Tom(trietz) has some sort of gizmo,,IIRC it's the velodyne SMS system,, far too complicated for me. Good luck,, I'm "old school",,guess I need to get my learn on.:)
    mhardy6647 Posts: 35,562
    edited January 2009
    Yes a spectrum analyzer and an RTA are most likely doing the same thing. Analysis is one thing; correction another.
    How about one of these?
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=248-661
    Cheap 'n' cheerful. The original version was well-reviewed by audioXpress magazine quite a few years ago.
    http://www.audioxpress.com/reviews/media/203hansen2196.pdf
  • Joe08867
    Joe08867 Posts: 3,919
    edited January 2009
    Had one of these for the band I was in. It worked wonders on the sound in certain rooms.
    I haven't tried it in a home setting but may just give it a try at some point.
  • jcaut
    jcaut Posts: 1,849
    edited January 2009
    It would require some additional hardware, but would this do what you want?
    http://www.hometheatershack.com/roomeq/
    I build DIY speakers and I used the calibrated measurement mic and preamp, etc. that I already had, but the program itself is free. I've used it with some success (in conjunction with a Behringer FBQ24/96) to tame some response issues in a church-sound application I was working on. It's been a while and I can't remember exactly how it worked, though. I never used it at home.
    Jason
  • thsmith
    thsmith Posts: 6,082
    edited January 2009
    jcaut wrote: »
    Jason
    +1 for Room EQ Wizard (REW) very useful tool. RS SPL works fine up to 3khz anything higher need to look at ECM800
