TSi100 or Monitor 30, or ...?
paradidl
paradidl Posts: 2
edited January 2009 in Speakers
I'm looking for a <$600 5.1 speaker setup for my Onkyo TX-SR606 (currently 5.1, thinking about biamping the fronts and maybe adding 7.1 later). I saw the TSi100 @ BB for 199/pr and they have a special this month for a free PSW10 or $199 off a PSW110 or PSW111 w/ a $499 purchase.
I like the sound of the TSi100 and am looking for bang for the buck. I'm probably 75% HT, 15% music, 10% Xbox.
I was thinking:
TSi100 fronts
CS10 center
OWM3 surround
PSW10 puts me just under $600, PSW110 puts me just over $600.
It looks like I can find Monitor 30's for about half price of the TSi100's and Monitor 40's for the same price as the TSi100's.
So, my questions are:
1. Is it ok to biamp the TSi100's w/ the Onkyo 606? If so, is there much difference in SQ?
2. Should I just get the Monitor 30's instead of TSi100s to save $? How much better are the TSi100s?
3. Should I get the Monitor 40's instead of TSi100s?
3. If I get Monitor 30 or 40's would they be voiced the same as the CS10, or do I need to find a CS1?
4. If I get the Monitor 30 or 40's would they be voiced the same as the OWM3? If not what is the suggested surround speaker, 2 more Monitor 30's?
5. Is the PSW110 or PSW111 worth the extra $, or should I just go with the PSW10?
6. Is there another model or brand I should be considering for my price range?
Post edited by paradidl on
  • paradidl
    paradidl Posts: 2
    edited January 2009
    I just noticed refurb RTi A1/3 and CSi A4 at Polk Direct in the same price range. Would I be crazy not to get these?
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    RTI A3's front
    CSI A4 center
    RTI A1's rear
    All for under $600
  • Hilbert
    Hilbert Posts: 316
    edited January 2009
    Absolutely get the better speakers for the same money at Polk Direct. I bought two LSi7s and an LSiC there. They arrived looking as new and packaged as new (I'm comparing them with LSi9s I bought new from Crutchfield). The only sign they weren't new was they didn't seem to need any breaking in.
    As for the sub, I had (have, stashed away in a corner) a PSW110. It was OK for movies but when asked to play music it sounded as if someone were breaking in through the basement. Not very musical. So I wouldn't splurge to buy one. (Although should be noted I never made much of an effort to dial it in.)
  • RutgersFTW
    RutgersFTW Posts: 458
    edited January 2009
    I had both a PSW10 and a PSW110. The 110 may have had more oomph and extension but I preferred the 10's controlled sound for music and movies. YMMV. I'd go for the RTis, but the TSis do have the benefit of instant gratification. :)
    Currently listening to:
    Marantz SR5004
    Sony BDP-S370
    Apple TV V2
    Audio Technica AT-LP120
    Mirage CMD-5 x 5
    Bic H-100
  • Upstatemax
    Upstatemax Posts: 2,741
    edited January 2009
    I would jump on the RTi's from Polk Direct.
    I picked up my FXi3's from them and they are perfect and at a great price.
    I was expecting to spend $400-500 for surrounds I ended up spending under $200 for a great speaker. :D
  • $mitty
    $mitty Posts: 33
    edited January 2009
    I've got a HT set up with the TSi series and I love it. I know they're not the best Polks you can get, but with a pair of 200s and a pair of 100s with the CS10 and PSW110, it is more than enough to shake my living room. The piano black finish gives them an expensive/elegant look and matches my TV and electronics beautifully. Plus, I bought them for 60% off, so I couldn't pass up that deal!
    Mains - TSi200
    Center - CS10
    Surround - TSi100
    Sub - PSW110
    AVR - Yamaha RX-V663
    Movies/Games - PS3
    Music - iPod Nano
    Satellite - DirecTV HD
    TV - Panasonic 46PZ85U
    PSN - mrSM1TTY
