speaker grill cloth
goingganzo
goingganzo Posts: 2,793
where to get the good speaker grill cloth? what is the brand polk uses in their speakers? and how much a yard do it cost? i have herd that the parts experss stuff is not transparent when it comes to sound.
would i be able to buy some stuff off of polk? or your suplyer?
thanks.
  • MxStYlEpOlKmAn
    MxStYlEpOlKmAn Posts: 2,116
    edited January 2003
    ratshack carries some....;)...100% garunteed to be.....TRANSPARENT ;)
    Damn you all, damn you all to hell.......
    I promised myself
    Damn you all! - ATC
    F1nut Posts: 51,771
    edited January 2003
    Gonzo,
    Polk will sell you all the cloth you need.
  • Jstas
    Jstas Posts: 14,985
    edited January 2003
    The Radio Shack stuff is pretty good. They have it in a few colors too. Although some of it has a cheesy 70's look to it, it still works and is transparent. Cheap too.
    Expert Moron Extraordinaire
  • goingganzo
    edited January 2003
    thanks for all the replys i will try radio shack and if i have no luck i will try to get some from polk.
  • STUFFMD
    STUFFMD Posts: 381
    edited January 2003
    Joanne Ect fabric stores sell it ,maybe even the smaller stores, by the roll...various colors as well.....I only know this because my wife works in a fabric store.
    Good luck Stuff
    Your system is only as good as your weakest component...!
    OnkyoTX-DS 797
    NAD C270/ Mains
    Mains: LSI9's
    Center: Cs400i /Biwired
    Rear: Fx300i
    Rear Center:CS 245i
    Dvd: Onkyo DVS 555
    Vision RCA 36" Premiere Series
    Bang & Olfsen RX Turntable
    Psw 350 Front/Psw 202 rear
    Kimber Cable 4TC Mains HF
    Monster Originals/Center
    Kimber Interconnects
    Monster XP Everywhere else
    PS2/Gamecube
