wiring mishap
richta
I am attempting to replace the binding posts on a set of SDA 2s.
While doing do I damaged one of the black wires.It's about ten inches coupled together by a ring terminal with another piece five inches.The other end of the ten inch section has a female disconnect either 1/8" or 3/32.
Any suggestions for replacement?
I spent the better part of today searching for that disconnect locally to no avail.
Thanks in advance.
RT
Thanks in advance.
RT
Post edited by richta on
Try Parts Express or just solder directly onto the post.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
Any guesses as to what kind of wire to purchase?
I'm not an expert, but I'd imagine regular speaker wire would be fine. Keep it the same gauge as original, and get some decent wire and you should be fine.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
