Speaker mount recommendations
guest
guest Posts: 12
edited January 2009 in Speakers
Need some help here--I just bought a Polk RM85 system, plus a sub. I would like to mount the rear speakers on the wall, but would like them to point downward toward the center of the room. The included wall mounts don't allow the speaker to pivot. Can anyone recommend a good speaker mount that would fit the rear RM7's?
Thanks!
~MG24
