Dumb Question
dontknowmuch
dontknowmuch Posts: 2
edited January 2009 in Vintage Speakers
Hi,
How many watts does the RM1000W subwoofer have? I'm trying to sell it and I was asked the question. I am guessing 1000 watts, but you never know!
Thanks!
Post edited by dontknowmuch on
  • zingo
    zingo Posts: 11,258
    edited January 2009
    The RM1000 used two 6.5" drivers and a 10" passive radiator, power handling was 125 Watts/channel, with a frequency response of -3dB from 42 Hz to 200 Hz.
    I hope this is what you're looking for and welcome.
  • dontknowmuch
    edited January 2009
    Thanks, I told the person 125 watts per channel and this is their response
    "That`s not the sub info,a sub is omnidirectional (no right,no left channel)
    Do you know what they are asking?
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2009
    Maybe they are confused in that some subwoofers are powered with their own on-board amplifier. This unit does not have an on-board amplifier. It must be hooked to an external amplifier. A sub generally combines left and right channel signals and acts as only one channel and a sub is omnidirectional (hard to pinpoint the source of the sound) and used to supplement the bass signal from a 2 point stereo or (multi-point surround) sound system.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • BigMac
    BigMac Posts: 849
    edited January 2009
    Here is the product spec sheet for your sub. Send this to them and it should answer all their questions. Omnidirectional when talking about subs means that the sound travels in all directions, 360 degrees. Hope this helps you out.:)
  • average_guy
    average_guy Posts: 236
    edited January 2009
    Bass frequencies are omnidirectional by nature, no matter what the source.
  • George Grand
    George Grand Posts: 12,258
    edited January 2009
    Plenty of confusion here, and none of it is coming from the prospective buyer.
  • seeclear
    seeclear Posts: 1,244
    edited January 2009
    Asking how many watts it has, it sounds like the buyer thinks it is a powered subwoofer. It is not, it is passive (powered by the receiver/amp).
    NJPOLKER's link was spot on.
    Hope this is what you are looking for.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
