Speaker Foam Repair Kit
Hi:
Im using an Infinity RS-325 as Surround and Polk RTi4 as Back Surrounds.
I have one of the Infinity Speakers that does not sound as good as the other.
I read there are some Foam Repair Kits. Any one do this before?
Which one you recommend?
Check this:
http://www.speakerrepair.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=11-003-B-INF&Category_Code=
http://cgi.ebay.com/Infinity-RS325-Speaker-Foam-Repair-Kit-Woofer-Refoam_W0QQitemZ9737882046QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Check this:
Panasonic 65" Plasma
Pioneer SC81
PS4 BluRay / Memorex BD-Player
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Monster Power HtS 1600 Power Line Filter/Conditioner
Pioneer SC81
Polk RTiA7 Fronts
Polk CS2 Center
Polk RTi4 Surrounds
Eomtiva XRef12
Post edited by javygonx on
Brother did it to a pair of old Advents ( know for there foam going bad)
He said it was the biggest pain in the a#@. I have never done it but he is a very handy guy and I really trust his word.
Hope this helps -
I have done one pair. An old pair of AR6 speakers that I bought at the thrift for about $10. I didn't find it too hard at all . In fact , it was very rewarding to get them speakers working well again. I would recommend the ebay kit . Also google speaker refoaming for some helpful pictures.Feel free to ask me anything . Again , I only did it once but I'd do it again in a heartbeat. While you have the drivers out to refoam , consider recapping the crossover. Good luck .
RussTechnics SL1210mkll / AT125LC / Cambridge Audio 640P / Yamaha TX-950 / Onkyo TA-2600 / Yamaha C-80 pre/Adcom GFA 545 / Polk Audio Monitor 12 Series 2 -
You have to be very careful and make sure that the coil/cone is properly aligned when you are gluing the new surround. Some kits come with the inserts, so that you can cut off the dust cap and insert those sticks/inserts around the coil to keep it evenly aligned.
I reconed one 15" speaker before and the kit did not come with the inserts. It was pretty painful.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
