Mounting CSi-A6 in the wall (yes you read that right!)
Drunkcaballo
Drunkcaballo Posts: 24
edited January 2009 in Speakers
So I had two weeks off from work for the holidays and started shopping. Now Im broke and the proud owner of a pair of A7s an A6, a DSW Pro400, an Onkyo 706, and have an XPA-3 ordered and on the way. Some FXi-A6s are in the near future. Ill probably be getting 2 pairs since I have a pretty open room (20x16 and vaulted ceilings). Anyway my main question is: has anybody ever mounted their CSi-A6 in a wall? Follow the link below to a picture of my setup for a bit more clarification. Ive got a cubby in the side of my house for a CRT style TV. Ill be boxing this in and mounting my 46" or 52" on it (shopping for that now). I was thinking of leaving a pocket open to slide my center channel in giving it a cleaner look. It will still be pretty airy back behind it for the ports so it will have good airflow. Is there any reason this would be a bad idea? Any suggestions/feedback would be great. Im thinking Ill have great sound and a clean look. :)
http://www.polkaudio.com/forums/showcase/view.php?userid=94116
RTi A7: Front Channels
CSi A6: Center Channel
FXi A6: 4 Surround speakers
JL Audio Fathom 212 Sub
Onkyo 706: Receiver/Pre-Amp
XPA-3: Front Channel Amp
Samsung 50" Plasma: PN50A450
Samsung Blu-Ray
Pre-Amp: Rogue Magnum 99
Amp: B&K Reference 200.2
B&W 805D
DSW Pro 400 Sub
Pro-Ject RPM 1.3 Genie Record Player
Pictures: http://www.polkaudio.com/forums/showcase/view.php?userid=94116
Post edited by Drunkcaballo on
  • Drunkcaballo
    edited January 2009
    Testing my sig.
    Yup it works.
    Samsung Blu-Ray
    B&W 805D
    DSW Pro 400 Sub
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    Nice setup. You got some serious toe in action going on with those A7's or is it just me.
  • Drunkcaballo
    edited January 2009
    Yeah there is quite a bit right now (less than there was before). Im still playing with the setup. I just hooked up the center channel and it made a HUGE difference.
    Samsung Blu-Ray
    B&W 805D
    DSW Pro 400 Sub
  • leroyjr1
    edited January 2009
    They might be too far apart as well. Play around with the placement to see what sounds best.
  • megasat16
    megasat16 Posts: 3,521
    edited January 2009
    The previous poster said it right. The speakers are too far apart (very close to the rear wall) and toe in is too much. I think you'll get better sound quality from
    1. Move the Speakers 1-2ft minimum from the rear walls.
    2. Bring (left and right) speakers closer so the distance between them is less than 10ft apart.
    3. More straightening the speakers so the toe in is not too much. You'll lose dynamic and stereo imaging if toe in is too much and the focal point reaches before your seating positing (which is usually called the sweet spot).
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • Drunkcaballo
    edited January 2009
    Thanks for the advice. The speakers are now about 7 feet apart. I have them about 10" off the walls. Anymore than that and they just are sticking out too much. Shifting them in has definitely given the room a fuller sound. Ill be taking some new pics in a week or so once I get it completely setup and adjusted.
    Anybody have anything comments/advice regarding my plans with the center channel?
    Samsung Blu-Ray
    B&W 805D
    DSW Pro 400 Sub
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    edited January 2009
    hope csi a6 is not cherry finish, it be shame to waste its beauty.
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
