Rti 6
RJaco
RJaco Posts: 113
edited January 2009 in Speakers
I am putting together my for ht system and have these speaker coming for fronts. I haven't seen much on here about them and was wondering what to expect. They will be used in a 5.1 system with a sub. Still trying to decide on sub. Going with Energy c-r 100 for surround. Will the Energys sound good with the Polks? One more question. How much better does the CSi A6 sound than the A4? Polk Direct doesn't have the A6 right now but does have the A4 for $150 plus $20 shipping? Is it worth waiting on the A6. Thanks for any info you can give me.
Post edited by RJaco on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2009
    First welcome to the Forum. The rti 6's were replaced by the new RTI A3's. The rti6's are good bookshelf speakers and will work great with either the csi a4 or a6 with the A6's being the preferred center speaker. If possible I would keep it all POLK Audio. You can get some RTIa 1's for the rear from Polk direct for about $150. As far as subs go I would look at the dsw series polk subs. It'll match with your rti6's very well.
    Keep use posted .
  • nm4710
    nm4710 Posts: 97
    edited January 2009
    The RTi6 is my favorite of the RTi line. I've heard (and owned) most of the line...the 6's are the sweet spot if you ask me - they look great, sound the most balanced, and are affordable (and easy to power!). You will be very pleased with them.
    From a technical standpoint the CSI A6 or CSi5 would be the best center to use with these speakers, but speaking from personal experience there is not a huge upgrade in sound from the CSI3/A4. If budget and size are issues (the CSi A6 is enormous) then you should look into the smaller center...it'll still sound great!
    As for surrounds, I would try to buy the same brand and line of surround speakers. You can get great deals on RTi4s and FXi3's from ebay (Polkdirect)...why not stick with those? I don't think the energy's will sound bad...but an all-RTi lineup would prob sound better.
  • Willow
    Willow Posts: 11,258
    edited January 2009
    I own the Rti8, Rti6 and Rti4 and a csi3.
    The 8's are kick **** hooked up to my 200w monoblocks. The rti4 where my rears till last week, now they are resting in storage, while I put together a small2ch. They sound very good. The rti6 are great so far, I know using them as rears is not getting their full potential, but oh well. For now they will stay as rears and perhaps be replaced again my the 4s once my little 2ch is set up. I too would have bought the csi5 but due to it's size could not fit it in the space, so the csi3 , again is great and it too is hooked up to a 200w monoblock. As mentioned you'd be best with all polks for your 5speakers but for sub, which ever you like and can afford.
  • RJaco
    RJaco Posts: 113
    edited January 2009
    Thanks for the welcome the help so far. You are a lot of help. The Energy speakers are brand new, so will just have to use them for a while. Maybe next year I can change them out. I will probably go with the CSi A4. I bet I have more questions later on when I start hooking things up. Funny, I was going to get a cheap htib system, then thought about a bose. After all the searching and reading online, now I think I am going to have a decent system for around $1000. Probably go with a cheaper sub and upgrade it later on if I feel the need. Got a Yamaha 6140 for the receiver. Hope it works for what I need. We will use it mostly for watching TV and movies. There are just way too many choices. I have changed my mind a hundred times.
  • Retro152
    Retro152 Posts: 985
    edited January 2009
    Welcome, I am currently running Rti'6s for my fronts, with a Csia6 center, all powered by a Yamaha-663. Have been very happy with the 6's, great speaker!
    Receiver: Pioneer Elite SC-05
    Amp: Emotiva Xpa-3
    Front L/R: POLK Rti-a9s':D
    Center:POLK Csi-a6
    Rear surround's:POLK Rti-a1s'
    Sub: Klipsch Synergy sub-12
    Sony Kdl-46w4100 46" LCD
    PS3
    Audioquest type 4 wiring.
  • RJaco
    RJaco Posts: 113
    edited January 2009
    Thanks for the help. I paid just under $200 for these speakers. Did I do alright? I am not sure since they are the discontinued model. Saw them on Amazon for almost $400. Since I have never had anything like this, I bet they will sound awesome to me.
  • RJaco
    RJaco Posts: 113
    edited January 2009
    Got a Yamaha 6140 coming. Will be here Monday. The RTi 6s show up Thursday. I hope to have them set up for the OU-Florida game. I live about 30 miles from Norman in Tuttle. Home of Jason White.
  • alibaba128
    alibaba128 Posts: 15
    edited January 2009
    I bought a pair of RTi6 recently. I may not have hundreds of hours of listening time on the 6, but I do have quite a lot on his little brother the RTi4.
    My initial impression was that, while the RTi6 has a more abundant bottom end, it is a bit less defined in the lower mids and mid-bass compared to the RTi4.
    HT system (work in progress):
    -RTi6 fronts, CSi5 center (to buy), RTi4 rears
    -PSW505 sub
    -Emotiva UMC-1 pre/pro (waiting for retail release)
    -Emotiva XPA-5 (to buy)
    -Raxxess ERSS-36 stands
  • ZOOPDOOP22
    ZOOPDOOP22 Posts: 158
    edited January 2009
    I ran the 6s and the 8s biamped from my receiver. Both sounded very very good but the 8s of course were much more.. full?
    I think that is the best way to describe it.. just more of the same good rti sound. I was very happy at this point to move the rti6s in back.
  • alibaba128
    edited January 2009
    anonymouse wrote: »
    what are you driving them with? your observation tells me that your amp has an insufficient damping factor and is running out of steam.
    I'm driving them with a Nad C320BEE integrated amp which is conservatively rated at 50 wrms per channel. I was far from driving the amp too hard; I'm positive the Nad had plenty of power left.
    -PSW505 sub
