OWM3s as rears with Rti fronts & center?
NewHTguy
NewHTguy Posts: 584
edited January 2009 in Speakers
Could use a little help. My sofa is backed up against a wall. I have Rti10's and a Csi5 up front and r50s as rears (these were my old fronts). I would like to replace the r50s because their placement (the sides of the sofa) just plain stinks, both acoustically and aesthetically. Does anyone know whether the OWM3s will blend with the Rti's up front? I've made many mistakes with this hobby :o and would prefer to not buy rears that have a poor timbre match. Having said that, I am willing to give up some SQ for the relatively sleek design of the OWM3s. (Sometimes I think I should just go to a 3.1 set-up but that is another thread... )
Thanks!
MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
BENCHED: CS20; OWM3s
Post edited by NewHTguy on
  • polrbehr
    polrbehr Posts: 2,842
    edited January 2009
    I don't see why not, though I have not heard the OWM3s myself, sorry.
    They look versatile as Hell, very impressive little speaker.
    If you get them, make sure you set your surrounds to "small" in your AVR.
  • jaginger
    jaginger Posts: 12
    edited January 2009
    I am planning on using the OWMs with RTiA3's and a csiA4 up front. My guess it they'll be fine, but I can let you know.
  • NewHTguy
    NewHTguy Posts: 584
    edited January 2009
    Polrbehr/jaginger,
    Thanks for your comments. I'm surprised there is no one else out there with the same set-up.
  • Eric W
    Eric W Posts: 556
    edited January 2009
    It's not as close of a match as say- the FXi or TCi in the rear- however the OWM has a sound quite similar to the RTi, particularly if you're going to be using them as surrounds. Silk dome tweeter, similar driver and similar voicing. I'd say go for it. :)
    -Eric
    -Polk Audio
  • NewHTguy
    NewHTguy Posts: 584
    edited January 2009
    Thanks Eric,
    I will probably give them a try. I really don't listen to much multi-channel music, so I guess they can't be that bad.
