How to set the tracking force on my TT?
nadams
nadams Posts: 5,877
edited March 2009 in 2 Channel Audio
I have a Technics SL-MA1 TT, which appears to have adjustable tracking force on the tonearm. I'm having issues with some LPs having a lot of sibilance... almost a static in the highs. It's weird, though, because some LPs sound great, like Green Day's Warning. Then I put on Billy Joel - Stranger, and every high note on the piano, and every "s" that he sings sounds like nothing but static. Both LPs are brand new, and in perfect condition as such.
Anyone know what I can do to resolve this? My thought was that the downward pressure on the cartridge needs to be adjusted, but when I did that using the little dial on the back end of the tonearm, nothing appeared to change. It's possible that this little dial is broken...
I'm using an Audio-Technica ESCAT301 cartridge with the Shibata diamond stylus. Vertical tracking is said to be 1.0-1.5 grams. I'd love to set it to this, but the dial on my tonearm doesn't have a marker to designate what the setting is??? It has numbers on the dial for grams, but no reference point on the arm itself.
Ludicrous gibs!
Post edited by nadams on
  • nadams
    nadams Posts: 5,877
    edited January 2009
    Also, the tracking force dial spins around with no stops, so there's no way for me to even guesstimate what it's set to. I'm guessing that it must be broken.
    Ludicrous gibs!
  • ESavinon
    ESavinon Posts: 3,066
    edited January 2009
    p mount?
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • ESavinon
    edited January 2009
    I believe this turntable is a p mount design.
    You don't have to set tracking force on a p mount design unless it's severely out of adjustment. Do you have the manual? They're easy to get online.
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2009
    What Keiko said but when your arm is balanced and floating turn just the outer part of the dial (should be split..a large counterweight part with the little free spinning dial on the end) to zero without upsetting the balance. Then turn the larger counterweight and the little marked dial together up to your minimum tracking force (1 gram). If you still have sibilance keep turning the whole counterweight unit up until sibilance disappears. I have on occasion had to run slightly higher than the maximum recommended tracking force for some cartridges to get rid of annoying sibilance. Good luck. Here is a link to a good read on general cartridge setup.
    http://www.soundfountain.com/amb/ttadjust.html#INTRO
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • nadams
    nadams Posts: 5,877
    edited March 2009
    Finally got around to fiddling with the TT tonight. Once I followed your instructions, the sibilance went away. Seems I had it about a gram too heavy. Thankfully, the cartridge/needle didn't appear to have any damage.
    Had to actually mark the weight, as I didn't see any mark already on it. Then I had to hold the outer dial while I turned the weight, because it spun with the weight. But now, all is good. I just need to figure a way to clean the records better than my dry brush can manage :)
    Thanks for all your help.
    Ludicrous gibs!
  • thsmith
    thsmith Posts: 6,082
    edited March 2009
    To give me piece of mind on how I had my tonearm weight set I checked it with one of these and I was right on. Worth $16 IMO and with coupon can be had for $10. I have seen people sell them on ebay for nearly $100.
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93543
  • thsmith
    edited March 2009
    Yep, I have to remove my plater to make the measurement. Its pretty thin. Let me know if you would like a pic or 2.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited March 2009
    Speaking of HarborFreight and cleaning records, I picked up a couple of these clamps on sale for 2.99 ea. I put them on each side if a record and clamped down. Makes a set of handles for hand cleaning the record and not having to worry about getting the label wet. Tested it on a couple of records and seemed to work fine. Results may vary.
    http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40993
    SCompRacer Posts: 8,520
    edited March 2009
    Keiko wrote: »
    ^^^Polkie ingenuity at it's finest. :D
    +1!
    With an old, unplayable LP, it could also double as a shield (or a really big pacifier for a vinyl nut).:p:D
  • Polkersince85
    edited March 2009
    I figured this would give Ben a woodie:D
  • Dagoods
    Dagoods Posts: 32
    edited March 2009
    thsmith wrote: »
    Thanks, that was a really good find!
  • thsmith
    edited March 2009
    Dagoods wrote: »
    Espcially since a friend found and bought for me as a gift ;)
  • inspiredsports
    inspiredsports Posts: 5,501
    edited March 2009
    Good thread!
    I sure love the idea of an electronic scale, and I may be wrong here, but I'm worried it would not be accurate on many turntables. The force applied at the stylus tip/LP groove junction is dependent upon VTA (Vertical Tracking Angle). If the thickness of the scale is thicker or thinner than the thickness of your specific platter with an LP on top of it, would the scale's measurement would be off a bit?
    I guess the Shure balance gauge has a margin of error also, but it does allow you to line up the balance beam with the stationary side pretty accurately at the exact record groove height on your specific turntable.
    I've found an interesting take on VTA here: http://www.tnt-audio.com/sorgenti/vta_e.html
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Fongolio
    edited March 2009
    Very interesting read. I will spend a lot less time on that particular parameter when setting up my turntables from now on. I could never hear it either.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Ben's IC's
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2009
    When adjusting the VTA you can tell if you've got it right because the music SNAPS into focus and it is not subtle.
