Center speaker question?
williamgauci
Hello, still new here and I love all the information here. I just picked up some RTi6's that i'm going to be using for my fronts and moving my RTIA1's to my sides. Question is,will my CSIA4 center match well with the 6's or should I be thinking or moving up to the CSIA6? I haven't set everything up until I can build some new stands so i'm waiting to see how everything sounds together with my Yamaha 6080. Any advice would be appreciated. Thanks.
_____________________________________________
Yamaha 6080 Emotiva XPA-5 CSi A6 RTiA-7's RTi A1's Velodyne DLS-4000R
Post edited by williamgauci on
The CSi A4 should match just fine with the RTi6's. I'd consider going to the A6 if you ever get any of the RTi towers though.
Sounds like you're gonna have a pretty decent setup when you're done. Are you running a sub with it as well?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
The csi a6 would be the preferred center but it's also very large. Both csi a4 & csi a6 will work great with your setup. If you plan on going with floorstanding fronts in the future than go with the larger csi a6 center.
Thanks for the advice, yea, I am running the old PSW10 that came with my first RM6005 5.1 set. That's my next upgrade whenever I can convince the wife I need to spend more money to make the house shake._____________________________________________
Yamaha 6080 Emotiva XPA-5 CSi A6 RTiA-7's RTi A1's Velodyne DLS-4000R -
Welcome William!
The Csi A4 would match but for maximun pairing of I would consider the CSi A6 to give you that dynamic range for sound. For the A6 fills the room with warmth that sometimes makes me cry . Oh by the way I hope you got the room because the A6 is a HUGH BOY!Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
Velodyne DPS-12 (Sub)
EMOTIVA XPA-5 :cool::p;):) -
Oh william, you can check polkdirect on ebay for the A6 if you heading that direction, they got some nice prices $179Samsung-55 LED
Denon 3808ci
RTi A5 (Fronts)
CSi A6 (Center)
FXi 5 (Rears)
Thanks, I'll have a look._____________________________________________
