cleaning plasma tv's
sda2mike
sda2mike Posts: 3,131
edited January 2009 in The Clubhouse
what's the best way to clean 'em??
thanks
Post edited by sda2mike on
  • Jstas
    Jstas Posts: 14,842
    edited December 2008
    Depends on if it has an anti-glare coating or not.
    If you still have you manual, it'll have cleaning instructions in it.
    If not, go to the manufacturer's website. they will likely have an electronic copy of said manual containing said cleaning instructions.
    Expert Moron Extraordinaire
  • first capital
    first capital Posts: 100
    monster makes a nice kit with cleaner and a micro cloth
    billbillw Posts: 6,847
    edited January 2009
    If you have any type of microfiber, or soft felt cloth, just get it a little damp and wipe it off gently. Those Monster kits are totally unnecessary. Just don't use windex or any chemicals. Unless you smoke in the house, burn a lot of candles, or pan fry a lot of food, it should just come off with the damp cloth. If that doesn't really work, use a little bit of gentle dish soap.
    For rig details, see my profile. Nothing here anymore...
  • steveinaz
    steveinaz Posts: 19,538
    edited January 2009
    The safest, most effective way I have found is a chamois and warm water--well wrung. This is the only thing that touches any of my audio equipment.
  • Jstas
    Jstas Posts: 14,842
    edited January 2009
    If you go to Staples, you can get screen cleaner for anti-glare screens. I've been using them for years on very sensitive and expensive computer monitors with great success and no ill effects. Also, the anti-glare cleaner will not leave streaks like water will.
  • jaginger
    jaginger Posts: 12
    edited January 2009
    Do the above suggestions work for RPTVs as well?
  • steveinaz
    edited January 2009
    I have a rear-projection DLP--the chamois works beautifully.
  • jaginger
    jaginger Posts: 12
    edited January 2009
    thanks, I'll have to pick one up!
