PSW650 on external amplifier?
infinitiqx4
infinitiqx4 Posts: 80
edited January 2003 in Speakers
Is it possible to bypass the internal amplifier on the PSW650 and use an external amplifier? What would the load be, and how much power could I give it?
I may be acquiring a Parasound 1500 which is rated 205x2 at 8ohm, 315x2 at 4ohm, and 630x1 at 8ohm. How would this work?
Post edited by infinitiqx4 on
  • scottvamp
    scottvamp Posts: 3,277
    edited January 2003
    Anything is possable - u could rip the plate amp off and what not.
    The real question is WHY????
  • faster100
    faster100 Posts: 6,124
    edited January 2003
    its a very expensive subwoofer, if you get a amp use it for mains or something.. or get a better sub. what could be lacking from a dual subwoofer sub with a huge amp on the back??
    the psw650 is a very nice sub, disableing amps and stuff kinda defeats the purpose.. its setup to handle said watts.. you add more you run into problems and sound is another issue.. you gonna add a crossover also? after you disable the inerts
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • infinitiqx4
    edited January 2003
    I already have the PSW650. I am going with a 5.1, but may be getting 7 channels of amplification since I'll eventually go 7.1 when I have a larger room. Wouldn't the sub sound better with a larger, better amp? Is there a way to defeat the internal amp?
