Bi-amping CS400
gene stangel
I recently bi-amped my CS400 center channel in an attempt to smooth out some sharp treble ( I think that the amp is still breaking in). I ran the center channel amp from an Acurus 200 watt to the mids and the output from a Marantz MA500 monoblock also powering a CS350 in parallel. So the Marantz is seeing a 4 ohm load and the Acurus I believe an 8 ohm load.
Anyone see any problem with the hookup or an I sending too much juice to the speaker. Thanks.
Post edited by gene stangel on
What?
Break it down, input to output.
Cheers,
RoosterCheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Lost here also.
Do we make things more complicated then they should be sometimes?? I wonderMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
MA500 - to single set of inputs on CS350, then wire from CS350 to
Tweeter on CS400.
Acurus - To Mid input on CS400.
I did this because the Marantz seemed smoother on the treble.
Thanks for your interest.
