Suggest Add-On to RM6880
zero hectic
Hi all. I currently own a RM6880 set that I'm very happy with, but would like to expand to a 7.1 system. Since the RM101 & RM201 are discontinued, I was looking for advice on what pair of speakers would make a good addition to my current system. I'd probably be looking to buy a new pair of fronts and use the four I have as my surrounds. Any help or ideas would be greatly appreciated.
Thanks.
Thanks.
Post edited by zero hectic on
I started with a rm6900 setup, ditched the sub and got a velodyne dps-12 and polk rm7400t pair for mains.they also go by rm50t in the pewter finish. I am looking to upgrade my center that is a rm6902 and not sure if its bigger then your current one but if thats what you already have im looking at upgrading to the rm7302 or rm7300.
I also just bought a yamaha sub as wel and though it says yamaha this yst-sw1500 blows away my velodyne.Polk RM40T Mains
Paradigm AMS 300 Surrounds-in wall
Paradigm AMS 200 Rears-in wall
Klipsch KG 5.5 Mains
Velodyne DPS-12 Sub
Yamaha YST-SW1500 sub
Yamaha M-70 Power Amp
Yamaha ns-777 2 channel speakers
NAD 216 THX Cert. Power Amp
Denon AVR-987 receiver
Denon DVD-757 dvd player
Sony BDP-S550 Blu Ray Player
Sony 60" SXRD 1080P Projection TV
Sharp Aquos 42" 1080 P TV -
Thanks for the suggestions. Might be more than I'm looking for, though. Not sure I want to go as far as floor standing speakers. Anybody using the RM8s?
