Html?
spwuinmk67
Anyone here deal with it or web design? Where is a good place to start learning or teaching yourself it? I found one website that explains it, but so far it seems to leave out a lot of explanations from what I'm seeing.
1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
Post edited by spwuinmk67 on
Try Dave's Site, it's not too bad
http://www.davesite.com/webstation/html/
The one from Maricopa is OK too.
http://www.mcli.dist.maricopa.edu/tut/
Those are both links that I have passed on to freinds in the past. Some liked one better than the other. If you prefer a book tutorial, the dummies series is pretty good. Also the one published by QUE will go into great detail and explnations as you work thru the book.
Sams Teach Yourself HTML and CSS in 24 Hours, 7/e
Hope that helps,
ScottWithout music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa -
I learn a lot from this site. Built for kids by a kid now young adult so you need to work around that a little, it's explains everything. http://www.lissaexplains.com/
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Do either of you work with html or any web design? How much of it is truely important to learn, or is there something else that would be more beneficial?1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com -
spwuinmk67 wrote: »Do either of you work with html or any web design? How much of it is truely important to learn, or is there something else that would be more beneficial?
If you can afford to buy software you should look at the Adobe CS4 Web Premium.. -
I'll look into it, I havent paid for much of the software I've gotten recently, such as final cut pro, adobe creative suite, vmware and a few others. I'm sure I can find a copy somewhere1993 Ford Ranger super cab:
MB Quart QSD216
Home:
52" Sharp Aquos
Xbox 360
PolkAudio XM tuner
