a few basic questions
Systems
Hello, I have 2 Polk/MOMO 12s and will be getting an Autotek MX-1300 this week. How do I go about breaking in my subs? Should I run it at 4 ohm? 2 ohm? Should I put HP and LP filters on?
Also I have an LED rockerswitch and I was told this is is firehazard if you dont set it up right...my question is how do I set this LED rockerswitch up to my remote and not have to worry about burning my car down?
Lastly... should I put (drill) ports in my back panel in my car to let more sound come through into the car?
http://www.millenniumaudio.com/html/a_amps.htm
That is the specs for the MEAN MACHINE MX-1300
Any help is appreciated.
Testing
Testing
Testing
Testing
Testing
