Groovmaster label saver
apc
apc Posts: 779
edited December 2008 in 2 Channel Audio
Anyone here ever use this device if you wash your records?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • strider
    strider Posts: 2,568
    I've always used a pint container from Chinese take out.
    That thing looks like it does a good job, though.
    Wristwatch--->Crisco
    SCompRacer Posts: 9,121
    I’ve got one I use on really gunky used LP’s to prevent serious contamination of my RCM/record brushes. Good sturdy design. You may have to push an O-ring back in place from time to time. No seal on the retaining knobs, so it may not be watertight for submarine (totally submerged) use.
  • dkg999
    dkg999 Posts: 5,647
    I just try to not slop too much soapy water on the label when I do the hand scrubbing on the kitchen counter. I don't even worry too much about spraying the label with the distilled water rinse. I dry the labels off with a paper towel several times during the cleaning process. I haven't had a problem with a label discoloring or coming loose, just leave the LP out to dry for about 20 min a side.
    Looks like a good solution if you're worried about your LP labels though.
    DKG999
  • ozzy21236
    ozzy21236 Posts: 100
    I have one. It no longer comes with brush. It does an excellent job or should I say it allows you to do an excellent job. Since I bought it , my urgency for an RCM has diminished greatly though I think I'll eventually make one. I recommend buying a nylon bristled brush made for cleaning records such as the nitty gritty brush or the Osage.
    Russ
    Technics SL1210mkll / AT125LC / Cambridge Audio 640P / Yamaha TX-950 / Onkyo TA-2600 / Yamaha C-80 pre/Adcom GFA 545 / Polk Audio Monitor 12 Series 2
