will tsi400 and Monitor 70's play nice together
zippty2001
thats what i want to know i have a set of tsi 400 right NOW and you can get good deals on the m70's so was thinking about getting some right now and a center but do the 2 mix??
Post edited by zippty2001 on
zippty2001 wrote: »thats what i want to know i have a set of tsi 400 right NOW and you can get good deals on the m70's so was thinking about getting some right now and a center but do the 2 mix??
The tsi series took the place of the monitor series. I asked eric wong the same question because I have a tsi center in the cs10 and monitor series for the rest of my setup. He informed me that I should be fine. The basically are a similar speaker as the monitors with a couple of changes. Hope this helps. Others will chime in.
BTW Welcome to Club Polk!! -
Are you planning to use both sets of speakers in the same room at the same time?-Eric
-Polk Audio -
well yes i would move the m70s to the front get a tsi c20 center and move the tsi400 to the back for 5.1
should be a ok set up right??? -
