pioneer a/v receivers
glemay
Hi, I have decided on Pioneer but i can't decide which model to buy. I'm looking more towards the Pioneer VSX-D811s since it is cheaper but I also like the Pionner Elite VSX-41. I will probably get the Pionner VSX-D811s over the Pionner Elite VSX-41, but will I notice I difference between the two. Is it worth the extra money to get the Pionner Elite VSX-41?
Main System:
Denon AVR-2805, Polk Audio RTi70's, Polk Audio CSi40, Polk Audio FXi50, Paradigm PW-2200 v.2, Toshiba 42XV545U HDTV
Second System:
Denon AVR-1705, Polk Audio R40, Polk Audio CS245i, Polk Audio R15, Paradigm PS-1200a
Second System:
Post edited by glemay on
I have a Pioneer Elite, I spent way too much time in the sound room. In a A/B test you can tell the difference. If you do not hear them side by side, who knows it ...depends on your ears... Can you demo them side by side?
hey dbournival i might be able to test em side by side but i'm not sure. I'm just trying to get an opinion. how much difference did you notice between the two?
thanks for the replyMain System:
Second System:
