Getting music off iPod
audiobliss
So, a good family friend gave me a 32GB iPod Touch for Christmas (yikes! I know, what a present! ). However, he opened it up, charged it up, and loaded a few things on it for me before giving it to me. There's a bit of music on it I wanna keep, as well as the new Batman movie. How in the world can I sync it to my computer to my stuff to it but without losing the stuff already on it? I guess the real question is, how can I get its current contents onto my computer? I thought about using it as a drive to get the info off, but apparently you can't view an iPod touch as an external drive.
Any ideas? They'd be great appreciated!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
Well, first off I would make a backup just in case anything gets screwed up. Here are 2 links for you to try out.....I have not tried it as my kids are at their inlaws with their ipods so proceed with caution. Hope this works for ya.:D
http://www.demystifyingdigital.com/iPods/Sync-Two-iPods/index.aspx
http://support.apple.com/kb/HT1495 -
I was under the impression that when you connect an IPod and sync it to the computer, anything new on the IPod gets transfered to the computer and anything new on the computer gets transferred to the IPod. So I wouldn't think you'd lose anything by doing a sync. But I could be wrong.Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH -
I think if Itunes thinks the Ipod is new to it, it will delete everything on it and replace it with everything in Itunes. YMMV
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Apple may have changed some things in the new updated version of Itunes, but before you used to be able to assign two pcs per Ipod. So in my case I would use my work laptop and home desktop without probs. Now that may have changed, not sure. Im sure theres some kind of software that allows this. I would search google for some underground site, I'm sure theres some awesome forums out there with tricks/hacks for this thing. I have had an 8 gig Itouch in the case for about 4 months now unopened. Have 3 ipods now, 1 U2 Spec. Edition sealed/unopened.Shoot the jumper.....................BALLIN.............!!!!!
I'm pretty sure you're wrong - when you try to sync with a new PC, it basically tells you it will delete any existing data first. Ostensibly to keep people from using iPods to pirate music and movies.
There are ways to copy music off of an iPod onto your computer - you can Google, but essentially you just mount the iPod as a drive and copy the files manually - but only if they're just MP3s and not "protected" mp4's. And you'll lose the filenames and playlists. Not sure if this works with movies - I doubt it.
I hope for your sake I'm wrong but I'm pretty sure this is the case.If you will it, dude, it is no dream. -
They make a program to do it, as far as i know though, its only for mac. You can search for it though and see if thats changed since i downloaded it. It's called senuti.1993 Ford Ranger super cab:
Pioneer Premier DEH-P880PRS
MB Quart QSD216
in need of amps and subs
Home:
52" Sharp Aquos
PolkAudio Monitor 10's
Harmon Kardon HK3375
Xbox 360
PolkAudio XM tuner
Owner and co-designer of www.basicholdem.com
