my new amps
Systems
Systems Posts: 14,873
edited January 2003 in Car Audio & Electronics
ill i have to say is i finnally recived my new amps
1 alpine v12 mrv-t420 for my m465's in front
1 alpine v12 mrv-t420 for 5.25 db's in rear
1 mrd500 sub amp for 2 mm100's
and Good God it sounds great
plenty of power,,,,, sounds as good as my friends thats running 350watts to each mm465 in the fron tof his ....whats so funny is he has more power to his componets than he does his subs bahahaha
go figure
i just want to say man.... polk makes a great sounding speaker......
and i hope they keep getting better
Testing
Testing
Testing
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited January 2003
    350 watts to a mm465?????
    is that total or per crossover
    if its 350w running to each crossover..
    thats brave man
    and i thought i was pushing the limit with 200
    i turned the gain down
    why didnt you get a bigger amp for your mm100s?
    250 each is kind of low for those speakers
    well im glad it sounds great!
    i got my components installed and man i love them
    waiting for the new 4x6's this summer
    what kind of car do you have them in?
    -Cody
  • Systems
    edited January 2003
    well so far for me the power is plenty, it may be that, i dont play my bass as loud as others, i like just to blend but i have not had them clip or anthing even when i have the sub up to loud for my likeing, also me having an acura integra "hacthback" may have alot to do with it as well, because there is not that much volume to fill i guess??????... as far as my gains on the amps, they are all set to "normal/or half way as far as it is listed on the amps
    and i would def, recomecnd the alpine amps to anybody, man i love my car system, it just makes me wont to sit in the drive way and listen
    wahhhhhhh whooooooooo
    go polk go
    Testing
    Testing
    Testing
  • sntnsupermen131
    edited January 2003
    glad you like it
    yeah having less space to fill will do that
    as far as getting in the car in the drive way and listening to it
    i feel the same way sometimes!
    it makes trips(even short ones) worth while
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited January 2003
    250 will make them move... its not gonna blow the doors off the 'tegra, but it'll do the job... the polk demo cars have it set up like that in some... we went through this discussion though...lol.
    i'm glad you're happy with the setup... those 2 channel alpines are friggin STUD amps aren't they?
    i've gotta retune my car myself.. after i get my damn doors back on (long story -- driving with no interior door panels.. and lots of sonic reverberation off hte metal panels.. i took dx9's and pt them inplace of my 6" midbass component .. cut out the tweeter wires.. idea is to give something between an 8" midsubbass driver and the existing 6" middy.)...
    sounds like ****-chunks right now....lol.
    The Artist formerly known as PoweredByDodge
  • PoweredByDodge
    edited January 2003
    go polk go
    i sooooo miss feelin like that about a car i did / have / whatever... lol... hopefully in the next month or two after i get this thing put back together and reevaluate my whole theory on crossover points (and maybe get a F***** digital EQ) i'll say "wahhhhh awhoooooooo" again. lmfao.:lol:
