should i 7.1 or not?
right now i have lsi25's for front, lsic for center and lsifx...so should i bother trying a 7.1 setup or is it not necessary?
Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
Post edited by eclimax13 on
how big is your room ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Also take in consideration there's not many 7.1 movies out there. Do you have any HD decoding going on?
My vote is stay with 5.1.
go for 7.1 if room size allows, not many movies out there in 7.1 yet however you can still take advantage of it . I say go for it .Shoot the jumper.....................BALLIN.............!!!!!
I'm a fan of 7.1 myself, but as people have already said, there aren't to many movies actually in 7.1 right now. If your room size permits it though, I say go for it. In the future there will be more releases that are dubbed in 7.1...so it's always nice to think to the future.
I feel that it adds a lot to movies though...when someone is walking up from behind you...it comes through the speakers that are actually behind you, rather than being next to you along the back wall.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
7.1 without a doubt, unless your in a very small room. gives a great transition from front to rear and soundstage even if it is a 5.1 soundtrack, if 7.1 then even better but well worth it IMO.
It's not necessary as most of what's out there is 5.1.
I've been waiting for 7.1 to catch on since 2002 so I wouldn't hold your breath on it taking off anytime soon.
7.1 just to splurge and be excessive !
Polk Rt800i -Fronts
Polk cs400i -Center
Polk fx500i -side surrounds
Polk rc60i -rear surrounds
Onkyo TX-NR 1009 (9.2) receiver
Velodyne cht12
Polk psw111 -
I disagree with that, its like saying theres no point in having more than 1 sub as it is 5.1 channels not 5.2.
Having the side channels fills the gap between front and rear regardless of 5.1 or 7.1 soundtracks. If your amp is 7.1 it will matrix the signal for the side channels so its not as though they are sitting there doing nothing, they are not a dominant channel in the system and for me in a 6 meter by 6 meter room well needed with great improvements allround in soundstage really enveloping the whole room.
Try it and see if you like it, this is the best way to find your answer.
