Which 6 1/2`s ??
FZSK$P
FZSK$P Posts: 4
edited December 2008 in Speakers
Got some aluminum wakeboard cans for the Jeep. Now it is time to fill them with some good Polk 6 1/2`s.
Using a Sony Marine radio.
No amp at this point but maybe in the future-If I can find a spot where it will stay dry and clean. This Jeep does see a far amount of off roading.
db461`s in the dash
The Polk 6 1/2`s I am looking at are
MM650
MM651
db651
The 650`s look promising but the reviews tend to tell me they need a good amp to work well.
Advice on what to use :confused:
