Toslink from one receiver to another
Igo
Igo Posts: 411
edited December 2008 in Electronics
I've moved an older receiver to the bedroom. The new one has one Toslink out. It is the MD/DAT out and it does light up the 40 foot cable but in placing it into the MD/DAT In on the older receiver I get nothing, even though I asign my 400 disc CD player to output thru the MD/DAT out. This is what I want to use for listening thoughout my house. Any suggestions here folks?
...Link to my System Showcase...
"ES - Kind'a simple but I like it"
Sony ES STR-DA4300ES 7.1
Sony ES SACD SCD-C2000ES
Sony 400 Disc CD CDP-CX455
Infinity BU-2 Sub-Woofer
Polk Audio RT800i Towers
Polk Audio CS400i Center
Polk Audio FXiA6 Surrounds
Sennheiser HD 280 Pro Headphones
DH-Labs T-14 Speaker Cables
Panamax Max 500 DBS Line Conditioner
Panasonic TH-50PZ85U 50'-Plasma
Play Station III - BluRay
Logitech Harmony 550 Remote
Logitech diNovo Mini Keyboard
Post edited by Igo on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I like ruling out things.
    So does the Toslink cable work if its connect directly to the CD player in the other room.
    If so it rules the cable, the receiver in the bedroom. So if it works that way then it seems to be a setting in the main receiver.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Igo
    Igo Posts: 411
    disneyjoe, I start ruling things out tomorrow too. So far my aproach has been to asign the optical out of my new receiver to send the digital signal from my living room CD player to the bedroom receiver. I'm not sure this is the way to go. Since this is strictly for whole-house background audio, I wonder if I can use the RCA outs on the CD player to connect to the living room player and use the 40 optical out to connect to the bedroom set up. Will the CD player output through bothe outs?
  • disneyjoe7
    Yes this is the way I did it. Optical from CD changer to the main system above it. I use the RCA analog outputs to feed a receiver for whole house audio, which are RG6 cables with RCA jacks on the ends running some 40 ft or so. Works fine, no problems with me. :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Igo
    Igo Posts: 411
    OK. Even though I have an ES SACD player set up in my main system already, I'd still prefer to run the optical out from my base model CD player (the 400 disc library player) to the main system then run RCA to the bedroom system but a 40 foot toslink is easier to run 40 feet than a set of 40 feet analog RCA cables. LOL.
    I'll let you know how it turns out. Thanks for the ideas.
  • disneyjoe7
    What you're complaining about 2 RG6 cables.... I ran 6 RG6 cables 3 pairs to closet. Now we are only talking about the whole house system, not the rest of the cables ran up that wall. :eek::eek::eek::eek::eek::eek::o
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • bikerboy
    bikerboy Posts: 1,230
    Hi,
    I tried something like that but I couldnt get the upstairs receiver to work with the toslink. Works fine with the rca outs. I guess its too long a run for the light, too weak a signal. I didnt try it with a shorter run to confirm. Too much trouble to move one receiver next to the other.
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
